Garmin 2699 uploading POIs - Help please! (2 Viewers)
ojibway
531
305
Eastbourne
since 2005
I have been following a range of instructions for uploading POIs onto my new Garmin - all helpful but I keep getting brain malfunction!
I have downloaded CCi POIs as I have used CCi for years and find them great.
I downloaded 'poiedit' to change the format from ascii to .csv and got my son to help using it.
Now I am ready (I think) to use the Garmin 'poiloader'. But it fails with a message "there was an unexpected error during transfer of custom POI files"
Here are images of the process and the files (Germany).
Can anyone help please?
ojibway
ojibway
531
305
Eastbourne
since 2005
Thanks, GJH, I'll try that though CCi did say to go for .csv
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
You don't need to convert the Ascii files, they are already in csv format. All you need to do is rename them, keeping the same file name, but changing the extension to .csv. So AA_CCI.asc becomes AA_CCI.csv.
By the way, if you install ATOTALES_CCI as well as the others, you are duplicating everything since this file contains all of the others.
What I do is use just the ATOTALES_CCI file for each country that I want to load. I then rename them completely (e.g. CCI_France.csv, CCI_Belgium.csv) and rename an icon bitmap accordingly (e.g. CCI_France.bmp, CCI_Belgium.bmp). Unfortunately you have to go through a renaming process as well as changing the file extension if loading more than one country since the downloads use exactly the same file name in each country. Hope this is clear.
ojibway
ojibway
531
305
Eastbourne
since 2005
Thanks JeanLuc,
I was wondering about ATOTALES_CCI and whether or not to use them
ojibway
ojibway
531
305
Eastbourne
since 2005
Hi JeanLuc,
sorry to be a pain, but I have followed the instructions for converting the .asc files to .csv using just 'renaming' - (right click - Rename - type new name 'CCI_France.csv') and the same for the Bitmaps.
I renamed all the ATOTALES that I want as you suggest.
I have also tried this using the PoiEdit with the same result
When I come to use the POIuploader I get the same "error" notice as before.
Any ideas?
Mike
JeanLuc
3,304
2,199
Warwickshire
Not sure about the top file in your list - it seems to be named as an ascii file still. I presume you have added the .csv file extension to the others but it's just not showing in your list.
Try uploading just the data files (csv) without the bitmap images: I have had trouble with some of these before being in a pixel format that the Garmin does not like.
Let me know how you get on.
18,032
48,115
It might be a formatting thing. The POI files I've recently uploaded to my Garmin don't have any header row in them. This is what one of them looks like viewed in Excel:
7.01023 45.76311 Arc en Ciel
8.481139 45.9335 Orchidea
9.12583 46.02529 Darna
11.81154 46.8081 Gisser
12.03703 46.77586 Corones
8.54992 45.81583 Solcio
Just Longitude, Latitude and the site name. The CamperContact POI file is the same. All are .csv files. If you are able to view your files in Excel check there isn't a row along the top with column names. If there is try deleting it.
18,032
48,115
I've just tried downloading the CCi ACSII file for Albania and opened one of the .asc files in Notepad. I then did a Save As but changing the file extension to .xls. I then opened the file in Excel which means going through a number of prompts including one where I selected commas as the delimiter. The file now looks like this in Excel:
19.81674 42.0995 KOMAN Aire CCI 17341
20.70973 40.90149 POGRADEC Aire CCI 6674
19.69845 41.47011 FUSHヒ KRUJE Aire CCI 26172
20.69787 40.89823 BUヌIMAS Aire CCI 26207
19.54207 41.92365 BARBULUSH Aire CCI 15897
19.97733 39.93361 NIVICE Bubar Aire CCI 16172
20.00619 39.77816 KSAMIL Aire CCI 21362
19.7271 40.10763 HIMARヒ Aire CCI 23698
19.46563 42.13836 SHKODヒR Aire CCI 24331
19.47804 41.18216 GOLEM Aire CCI 25696
19.85848 40.77914 URA VAJGURORE Aire CCI 26208
Which looks the same as the ACSI POi files which did upload to my Garmin successfully. I'm not entirely sure if they will work as I haven't tried uploading it, there are some weird characters in there, but otherwise it looks promising. It may not be necessary to load it into Notepad but that was a convenient way of renaming.
Of course the CCi data for each country seems to be made up of several separate .asc files. I'm not sure why that is but I guess you could open each one in turn in Excel and then copy and paste them to make one single file. Seems a bit of a faff and this might be a good time to give CamperContact a go! :)
18,032
48,115
Thanks for that, DBK.
Have you looked at 'park4night' ?
I've had a look at it but I still find CamperContact easier to use. I think Park4Night probably has more locations but the extras seem to be just basic car parks without facilities, which I'm not keen on as we like waste dumping facilities. The two screen shots below of part of the Pyrenees suggests they both cover the main locations. As always, I don't think there is one perfect app but CamperContact gives us enough choice.
Park4Night:
CamperContact :
ojibway
ojibway
531
305
Eastbourne
since 2005
Well guys,
I think I have sorted it!
I noticed that when the Poiloader asked for the destination (Find Device) it only offered Memory Card (H:\).
I had bought and plugged in a memory card as the Garmin showed it was 3/4 full.
I now have removed it and the Poiloader recognised the Garmin device instead and has uploaded without "error" showing up.
Now all I need to do is use it and see if it actually works.
Thanks for all your help - and patience(y)
Mike
18,032
48,115
Well guys,
Mike
You know, that was the first thing I thought of when I saw your original post, because on my PC the garmin shows up by model name "Nuvi 67" in my case. I should have queried it at the time! But alls well that ends well as some scribbler of old might have said, or possibly even did. :)
