Fridge fault (1 Viewer)
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Our fridge is not working on 12v when the engine is running, either on auto or manual. It shows fault 10 which according to the book means it does not "see" the engine as running.
Have changed the fuse and no joy.
Not a great problem it just means we are using gas when we need not be.
Any ideas what to look for please? :Doh:
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Not got a clue but I am sure Glenn knows, give him a call
Peter
Teasy2007
2,086
1,159
Rotherham South Yorkshire
Carthago Malibu PVC
We had that problem with our Autocruise. It was the relay which had gone. We found that the habitation battery would not charge from the engine, the electric step would not retract etc.
The relay effectively tells the engine it has a connection to the motorhome, or not.
Hope this helps.
Ginny
callumwa
4,110
4,480
Tyne & Wear, sometimes..
Thanks all. Not a great problem for us so will wait till we are back in UK. :thumb:
Ken. Have you checked your hab battery is still charging when the engine is running?
That could be a problem.....
43,358
49,637
separate relay's for fridge and charge(when engine running) Ken.
sounds like the fridge relay has quit.
probably near to the engine battery and with the charge relay.
usually just bog standard automotive 30a relay's
bobandjanie
8,171
15,834
Javea, Spain
Pilote V600g
Hi Ken, check if you have power at the fridge when the engine is running, could be the heating element gone we had this on ours but when on mains. :Doh:
You have two at the back of the fridge, 240v and 12v, google ' 12v Heating Element ' then you know what your looking for.:winky::ROFLMAO::ROFLMAO: If you look on the grey wires they say 12v or 240v on them, they just hang down the back, sometimes you can pull them out without moving the fridge. :Doh: ::bigsmile: Bob.
I'm not saying this is the one you want for your fridge, but it will look something like it !
