Fridge fans suck or blow (3 Viewers)
rrusty
258
212
None sold sept 2019
I got 2 fans fitted after last summer season and now I'm in Spain and been here for 4 days and the fridge is getting hotter and hotter by the day.
Fans are fitted top vent sucking the air out., clearly not working.
Reversed them 4 hours ago and they are now blowing hot air out the bottom vent and the fridge is chilled and working normally
The oven and gas option on the fridge are working normally as well.
Sep 10, 2013
1,187
18,726
Chelmsford Essex
Getting better
Hot. Air normally rises, so it would be usual to extract from the higher level. Maybe check the air space behind your fridge to ensure a clear unrestricted air flow around the heat exchanger on the rar of said fridge.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Always fitted in the top vent pulling out. Never any other way.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
If blowing the heat back down is helping cooling then the problem is you don't need the fans on at all yet
Sucking out the top is normal but if it's drawing heat away too much it will impede cooling
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
All the vans I have owned that had fridge fans fitted were in the top vent pulling out. They were all automatic being switched on by a thermo switch. They only came on when the outside temperature was in the high 20s and then only for a few minutes before switching off again.
Chris
21,056
279,050
10 years
I am glad you made clear this thread was about a fridge....
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
I've bodged a computer cooling fan into my top fridge vent using the spare terminals on the solar charge controller as the power source. It seems logical to have the most power available when the sun's at its peak.
One thing I reckon happens is that the metal draining board directly above the fridge creates a sort of feedback loop, where any heat that doesn't escape the vent properly is reflected back onto the fridge top causing it to warm up. As it warms up, the fridge burns more gas to compensate, thus creating more heat that can't escape from the vent and so on...
To my simple way of thinking, an extractor fan on the top vent will help to break this loop.
I may of course be totally wrong.
11,843
14,080
I fitted a 5" fan in the top vent, blowing outwards and it works fine when it is very hot (around 30C +). It does reduce cooling if its on when the temperature is lower though. Perhaps the reason yours appears to work better is that going against the normal airflow it will be less efficient and thus have less of a negative effect on cooling. I'm surprised it's hot enough in Spain yet to need the extra fan, usually temperatures are only in the mid 20s in May.
Aug 10, 2012
842
908
cambridge
Globecar
since2001
the correct term 'I think' :cool: is 'induced draught' i.e. blowing outwards at the top, i.e. inducing an air flow
but what do I know, I initially wrote draft instead of draught:)
fans can do induced draught and forced draft:whistle:
Aug 18, 2014
23,806
133,901
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Mine comes on at 30º but doesn't go off until temp has dropped . which doesn't normally happen until early a.m.
In Alicante Thursday night Friday a.m.I had to disconnect the sensor as the wife complained of the noise. Think I'll have to get a different sensor.:LOL:
You should move here.Been in the 30's all week, 34º today :( appears that it could be the same this year as last with temps in the 40's again, late June /early July.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
The last one I did I put two brushless computer fans in. No noise whatsoever.
magicsurfbus
4,673
10,127
NW England
Since 1997
I find the fan I've fitted reverberates on the MH side panel and creates an annoying humming inside the van which is louder than any noise made outside. I put rubber pads between the fan and the vent which helped reduce it a bit, but it's still quite loud. It would probably be anti-social using it on an aire, but it could be handy when taking a break at service stations or when shopping at a supermarket to keep the temperature down before the next stretch on 12v. I think I might look at a brushless fan as per @Snowbird now the wiring's in place.
Mar 10, 2016
558
617
A Class RMB 750HE
Three years and counting, 30 years a tent tower.
If you use your existing temperature sensor to decide when to switch the fan on the internal regulator on this fan will set the speed to match the temperature which should help keep the (minimal anyawy) noise down
2,347
10,196
lots of hot air on this thread..
FD and ID fans.. methinks someone worked at power station with boilers and steam turbines.. ;)
