Fridge door. (3 Viewers)
Apr 26, 2014
622
606
Thornton Cleveleys
2004 Bessacarr E735
3 years
While travelling with the caravan an item inside moved and has put a big scratch along the fridge door.
I've priced a new one at £135. It's a Thetford N112 with a curved silver/grey door.
We're now looking at selling the van to raise funds for our first motorhome and it sticks out like a sore thumb.
Has anyone had one repaired and if so who did it and what was the finished job like ?
Thanks in advance.
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
Is it metal and painted or plastic?, I should think one of these mobile places like chips away or summit like that would be able to help(y)
Feb 24, 2013
13,088
101,495
Bolsover, Derbyshire
Hymer S800
not long enough
There is a fridge door expert on here - I think his name is @DavidG58
I believe he may have a stock of spare fridge doors.
He's certainly the go to guy for all things fridge door related. :whistle:
:D:D:D:D:D
I have only got the two Dave, don't go giving the OP false hope :)
To the OP its a long story, save it till we meet one day, but mines Dometic anyway (y)
Nov 30, 2009
6,548
149,012
Pickering
PVC the PUG
If I were you I'd look into having it repaired. I know our fridge freezer looks to have a laminated plastic front to it . It matches the work surfaces, so I recon, there must be a way that you could take it out and change it , if you wanted. To repair or for a new look.
Feb 24, 2013
13,088
101,495
Hymer S800
not long enough
To be honest I was quite impressed with your price of £135 for a new door, you might find that is for the door without the panel though
Dometic want £400 just for a door I need due to broken fitting, which doesn't come with the décor panel, hope we can move ours across as that adds another £180
good luck with it
Tom A
Apr 26, 2014
622
606
Thornton Cleveleys
2004 Bessacarr E735
3 years
Thanks for the replies.
Here is my fridge.
I've emailed Thetford so I'll keep you informed of any updates.
11,932
9,097
Hi the front panel undoes and you can slip in a 3 mm ply board to match your cupboards or you can get brushed silver boards etc -easy to cut and do (y) simply cut to size undo the side screws and slide in -redo screws -refit door JOB DONE :D
terry
edit I have a sheet of silver-grey formica like stuff if you need it
Tom A
Apr 26, 2014
622
606
Thornton Cleveleys
2004 Bessacarr E735
3 years
Just a google picture Tony. I can assure you it's scratched. Could have kicked myself when I saw it.
Nov 30, 2009
6,548
149,012
Pickering
PVC the PUG
Hi the front panel undoes and you can slip in a 3 mm ply board to match your cupboards or you can get brushed silver boards etc -easy to cut and do (y) simply cut to size undo the side screws and slide in -redo screws it
Just like I thought then Terry ?
Bev
11,932
9,097
Yes Bev (y);) great minds and all that :D
I did offer to have a crack at repairing Davids door but it sounds like he bought a new one :rolleyes: simply too much money or he conned his Bev ;)
terry
