Freeview box
Discussion in 'TV & Satellite' started by sinbad1, Aug 7, 2009.
  1. sinbad1
    sinbad1 Deleted User
    Having problems with my Humax f2-1000t free to view digybox it came fitted to the vans dvd, reversing camera system.
    On two occasions now the remote fails to operate the box, I've put new batteries in the remote ;but this has made no difference. If i switch the unit off and on a few times all seems to work ok.
    So is it a IR problem, if it is then could be the receiver or the remote, is there a way of checking ?
    It may be easier to get another free-view box ;but the existing set-up would require an
    Rf modulator output as opposed to the Rf loop. So any suggestions on a cheap free view box with Rf modulated?
    regards
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,898
    6,157
    Mansfield,Notts
    You can check if the remote is flashing a signal by viewing the end through your phone camera keep pressing the remote fast and you will be able to see if it misses a beat or two:thumb:
    Geo
    Geo
  3. sinbad1
    good thinking batman, the remote and receiver both flash without any misses at the moment., then for some reason the digibox fails to respond. I suspect its may be the box as switching on and off several times seems to cure it. Software for the box is up-to-date.
    I did read somewhere that if the batteries go flat at any time this can cause problems ;but not found any info on that.
    Regards
  4. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    Any chance it's sunlight falling on the digibox IR receiver ?
  5. sinbad1
    Its housed in a top locker where the control panel is located so doesn't get any sunlight,The set-up enables free view via a scart lead to the a small monitor in the cab which can also show dvd's and auto selects the rear camera when reverse is engaged.
    Could get another freeview box cheap enough ;but would need one with RF modulated to feed socket in the rear of the van.
    Intermittent faults don't you just love them:Doh:
  6. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    Someone on TV was making a big thing of a "cheap" box to covert even black and white sets because it's RF out. But it was £39.
