ford transit (1 Viewer)
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
does any one know if when on hook up the engine battery recharges as well as the habitation battery .i just went for my mk 7 transit yesterday and it wont start flat battery i was hoping on hook up engine battery will charge any replies appreciated
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
We have a Battery Master fitted by Van Bitz & works well - don't forget to ask for Funster discount for any members thinking of having them fit/buying one:xThumb: See http://www.vanbitz.com/product/battery-master/
This is fitted free if having a Strikeback alarm fitted
or unit & fitting included in the price if if having a solar panel fitted see
Broken Link Removed
We aren't connected in any way just pleased with their products:xsmile:
SUGGY
1,311
2,201
scunthorpe
My Transit is a 2009 , with the Hab Bat under passenger seat and Engine ( Cab ) Bat under drive seat along side the bat charger ,
i mounted a battery isolater switch through the side of the seat base so i can switch over and connect both Hab and Cab together ,
I conected it in the +ve line between both sets of batteries
ie :- to the out put cable from the charger to the Hab battery and the +ve on the Engine battery ,
This enables the charger to charge Hab n Cab at the same time , i also use the switch to join the Batteries, when i am using Solar to recharge the Cab Battery as well as Hab .
Then i switch it off at night or when we are using the Inverter or lights etc on the Hab Battery ,
Lucas style battery Isolator/cut off switch fxd key 597 ( item: 111036585284 transaction:1113240308001 )
Broken Link Removed£10.99
May 29, 2013
2,598
19,231
Tyneside
Chausson best of Flash 10
Several years now
We have been told that our 2014 Mk7 Transit DOES recharge both batteries when hooked up. I have not checked this with a multi-meter, but the little LED lights which show engine & Hab battery levels, do go up on both with hook-up.
andy63
4,672
15,017
south shields
None
since 1990
hi , you may well be aware , but on the mk 7 transit the start battery will be isolated unless the engine is running.
if it is to be charged whilst on hook up it will have to have a dedicated charging circuit installed and as said above that will depend on the converter but would be easy enough to check with a meter..
when the ignition is switched on the batteries on mine combine and as long as a start takes place within a given time they continue to be linked. the above is the case with mine anyway , but my van has a start and aux battery fitted from ford..
ta andy
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
The same thing happened to me last week on a Mk 7 10plate. Went to take it for mot and battery was flat. As others have said It will not charge through plugging in EHU. I used a battery charger onto the jump point in engine, saves taking drivers seat off. Apparently its the immobiliser that discharges the battery.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
No hard and fast rules on this one!
Its down to the converters and whether they are intelligent enough to mate the base vehicle and caravan electrics properly.
I have come across electrical systems designed to charge the starter battery but didn't due to the converter being ignorant of the function of the Transit's optional factory twin battery set up.
A rewire sorted it!
Our Transit-based van suffered no problems with flat batteries in its original form due to someone being competent in Chaussons design team!
gpz
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
thanks for all the replys ive found out the engine battery doesnt charge on ehu but not a problem as ive found the point under the bonnet to jump start it ,it seems that if left for any amount off time the battery goes flat never mind i will just nave to use the van more
Sep 10, 2013
1,187
18,697
Chelmsford Essex
Getting better
As far as I can tell the Schaudt electoblock on our MH does charge the Transit engine battery when on EHU. That's from reading the wiring diagram and manual. Next time we're on EHU I will dig out my multi meter and check it on the under seat battery terminals.
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
most modern vehicles seem to run batteries flat very quickly its because we have radios with memory alarms and imobilisers that run even when switched of my work transit had a tacho as well and only went a little over a week if not run
joncris
1,101
1,603
Where it matters
Rimor Katamarano 12p +
We too had a battery problem for the 1st time last week in that the hab battery was flat. Engine battery was ok We then realized the hab electric hadn't been switched off at the control panel.
