Flat Hoses (1 Viewer)
Kingmal
38
4
York
Low profile
Just started (2 months)
Happy New Year all. A little help if possible. I am trying to find a company that sells FLAT hoses, I live Nr York, any suggestions would be welcome.:Smile:
43,332
49,527
try the worlds dustbin...EBAY....search 'flat hose'
usually hundreds for sale.
main problem with flat hose is you have to unroll the full hose and ensure there are no kinks along the whole length.
there are some which roll flat but have 3 smaller hoses (side by side) moulded as one which will work part unrolled.
best to avoid this one though.....rather pricey :ROFLMAO:
And another one, area of a circle is pi * r * r so by making r very small, even if 3 or 4 of them means the flow will be quite restricted.
pi * 6 * 6 = 113 sq mm 37mm circumference
pi * 3 * 3 * 4 = 28 sq mm 75 mm circumference
So not only 4 times less area there is double the wall length adding drag.
We have a couple of the cheap 12mm flat ones, not used much but work a treat.
Chris
21,056
279,010
10 years
Is this Greek?
::bigsmile:
Dec 6, 2011
11,596
25,450
South Wales
Coach built Adria
i use a cheap flat hose off ebay...:Eeek: i know blue food safe! is the real stuff but dont tend to drink the watewr from the tank unless its in coffee... :winky: dont know whats been in the tank even after a clean!!:Doh:
anyway
water is for washin, wine is for drinkin....................:ROFLMAO:
wasp
1,724
18,180
Warsop
None gone caravannin
I just use normal hose pipe and a watering can in case I cant get to the tap we don`t drink it only use for washing:thumb::thumb::thumb::thumb::thumb:
Jul 28, 2010
1,710
617
The world
Small car
OMG YOU MUST GET RATHER THIRSTY :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
WE USE BOTTLED WATER FOR DRINKING ( NOT SURE THE FRESH WATER TANK IS THAT CLEAN)
K
Kingmal
38
4
York
Low profile
Thanks for all the comments. Will try Go Outdoors first.::bigsmile:
mikebeaches
5,395
8,603
Bristol
Rapido V68 Van Conversion
We've had a flat hose wound on a cassette in the van for two years.... just in case. It hasn't been out of the box yet! We also have various other shorter lengths of garden hose and even a 5-metre push-on-the-tap food-grade pipe too.
Surprisingly, the thing we've used most for topping up the tank when out and about is a plastic watering can! Saw other people recommending them and thought that's a load of nonsense for filling 120 litre tank. And indeed, it probably is. But it's so convenient for topping-up whenever near a handy fresh water tap. Spent three and a half weeks in France in the summer and didn't use any of the hosepipes on board, just the watering can.
K
Kingmal
38
4
York
Low profile
Flat Hose
Thanks for that. Have a hard round hose which is difficult so thought I would invest in a flat one to save space, but may reconsider now. ::bigsmile:
