Kannon Fodda
- Feb 26, 2019
- 2,680
- 8,248
- Autotrail V-line 540
- I Make Schoolboy Errors!
So, I'm about to embark on some modifications, initially adding a WiFi aerial on a hold off bracket, but also contemplating a bit more solar.
I have a Ducato based PVC. So it's a ribbed type painted metal roof no doubt with some form of insulation under the metalwork and then the internal ceiling linings. I don't want to be pulling the ceilings apart to try and find methods of mechanical fixings through the metalwork. It's going to be challenging enough just to find a suitable small route for any cables above perimeter cupboard areas.
Plenty of posts suggest I should be using Sikaflex 552, being some a structural adhesive. Is this also waterproof to seal around fittings where the cable then passes through, preventing corrosion on the edges of the hole cut?
How do I ensure an adequate bond? Is it sufficient to clean and degrease the paintwork, and with what, some sort of alcohol cleaner? Will the paint be adequately bonded to the metalwork, or do I have to somehow abrade the paint back to bare metal (with the inevitable risk of corrosion)?
It does appear the existing, manufacturer fitted, 100W solar panel on aluminium bracket rails, and other fittings are simply bonded to the roof without mechanical fixings, so hoping I can repeat that process.
