Fitting swivel cab seats to mk7 (07) reg transit (2 Viewers)
whitem
11
Chichester, West Sussex
Hi all
Does anyone know if fitting a drivers swivel seat on a mk 7 transit(07 Chausson Flash 03) is possible?
Have been told lots of varying advice, such as:
- can only supply FASP passenger side as drivers side fouls handbrake (www.marcleleisure.co.uk)
- can supply MAPA swivel either side for transits year 2000+(outdoorbits.co.uk)
WHAT do I do?- thinking of just ordering the MAPA and doing it myself, but I have seen a few chaussons (low profile flash's I think) with both cab seats factory fitted with FASP - looking swivels
Thanks for any advice!
Mark
American Dream
156
Lincoln
Hi Mark...
I thought hard and long about fitting swivels to my "c" class....
Turns out it wouldn't really work for me...You'll really have to sketch out a plan of the cab area and work out the clearances....
Hopefully someone will get back to you who has looked into/performed the conversion...
Steve.
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Hi all
Mark
I don't know if possible but I do know it is probably the best single mod I've made to our Fiat. The bonus of an extra comfy seat not taking up floor space is immense. So keep looking it is worth it.
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Thanks John Cross, but all the swivel seats you sell are NOT specified for Ford Transit!!!!
Can anyone else can help?
Hi,
We can supply a Transit passenger swivel, they cost £215 less Funsters discount but they are special order and not on web as you say.
If you want one please give Darren a call on 01-580-881288 and he can advise etc and order.
Regards
Peter
RichardnGill
183
Durham
I fitted 2 swivel seat bases to our 2007 Transit no problem, then took them off and sold them before I sold the van. Depending on the layout in your van they can give a lot more space.
The only downside on the Transit is the drivers seat will not swivel with the handbrake on.
We got ours from http://www.motorcaravanning.co.uk/shopuk/seat_swivels.htm
They were good value at £130ish including delivery
Rich..
W
whitem
11
Thanks Rich, very helpful - was it the CTA swivel (£126 + VAT) that you fitted?
I only ask as I know that in a new Chausson Flash 04 I have looked at, there were FASP swivels fitted (which are over £200), and I could see that the manufacturer had cut down the plastic trim on the side of the seat (where the up/down levers are) to allow the seat to clear the handbrake in the down position. Did you have to do this too??. Were they relatively easy to fit? I fitted some on my previous Fiat Ducatto 54 reg and it was quite straightforward.
Also, Rich, did the swivels you fitted raise the seat by a lot?. Really want the swivel base that raises the seat as little as possible as the wife is only 5ft 1in !
Many Many thanks again,
Mark
jeffscarborough
12
Scarborough
2 years
I have a Dethleffs SE1 camper 2009 Ford Transit 350 cab with twin swivel seats fitted, I guess by Dethleffs.
The hand brake is fitted in the step area by the drivers door, so no clearance problems.
RichardnGill
183
Durham
Hi Mark
I am not sure what make they were but they were about £130 each. I took the plastic trims off ours. But you could cut them down if you wanted. Our handbrake was on the door step and the seat will still foul it when the handbrake is on even without the plastic trim. The only way was to turn the seat with the handbrake off, if you are on leveling ramps this an be a hassel. I use to get one of the kids to put there had on the foot brake and turn the seat and then put the handbrake back on.
If you have a Google about there are a few suppliers and some good prices.
They are an easy job to fit, I was say 30 mins a side.
Yes the seat was higher by just over an inch, this was a problem for me as our van has Remius cab blinds which reduce the hight of the windscreen by about an inch. I am 5'11" and always seemed to have to look under the top of the window. I would try lifting the seat up an inch and make sure you are ok with it at that height.
But honestly it did make our van much bigger and it was a very similar layout to yours (Hymer C622)
W
whitem
11
Thanks again Rich,
Think I will go for the MAPA swivels (side lever as opposed to fron lever to swivel), good value at £130, just one more thing though - did your drivers seat turn all the way round and clear the steering wheel?
Good base vehicle the transit I must admit, but I have heard that there is a software update/upgrade which smoothes out the jerky / stalling tendencies it often has - did you or any other forum members have this done ?
Great advice again Rich, thanks
Mark
RichardnGill
183
Durham
Mark now I come to think of it I think they were MAPA seat bases
Yes the set will clear the steering wheel (The transit wheels is nice and small which helps) but like most vans you will need to pull the seat forward to swivel it then push it back again until it reaches the steering wheel. Our Fiat has factory fit swivels and you have to do the same, the biggest difference is with the X250 fiat you can turn the set with the handbrake on.
Our Transit was a 2007, 2.2 130BHP and it was very easy to stall and ran poor after you had stalled if for a short while. I got the software update done and it was the same, but that was in 2008, I guess they might have a newer update by now.
Rich...
W
whitem
11
Great thanks Rich,
Going to order a MAPA from www.motorcaravanning.co.uk as they are cheap (£135) and I have had some great advice via email from the Neill at the site. Hopefully should be OK to fit.
Will get the Ford software update done at next service I think, along with any recalls while I am at it.
Thanks again Rich, great help.
Mark
Oct 29, 2008
5,073
5,974
West Yorkshire
Rich..
I bought them from Rich. Had them in my Flash 03 2006 Transit with no problems, I have sold them on again as I sold my Chausson last year.
One was a Mapa one was a Fasp cant remember which though. The drivers side was a lot heavier built, maybe Rich will remember.
Oct 29, 2008
5,073
5,974
West Yorkshire
Great thanks Rich,
Mark
They are a good company to deal with, I recently needed a part for an awning and they were great.
Scotties
439
318
Hymer
Swivel ...
Hi guys, the German made transit swivel clears the brake by being slightly higher (pain if you are over 6foot) and more importantly, is offset to the middle of the van, neatly moving the seat out of the way of the hand brake.:thumb:
Regards Richard
W
whitem
11
Regards Richard
Thanks for your comments Richard, but is the 'German made transit swivel' a MAPA, CTA or FASP?
Mark
EMS
Jan 8, 2010
200
181
Hants Sussex border near
Coachbuilt Low
Started 2009!
Hymer seats
Our 2007 Hymer 572 also has swivel seats, probably the same as the Dethleffs. (same company).
The drawback is that they are rather high so a short person would have a problem, the handbrake is mounted in the step so can be awkward unless one is like a gorilla.:Smile:
I am not certain if handbrake extenders are available for the Mk7?
W
whitem
11
Hi all,
Have finally got a MAPA swivel which I fitted myself in 45 mins or so. It was very heavy and well made but also quite stiff to swivel and raises the seat higher than a FASP which I had in my previous ducatto.
Not sure why FASP dont sell driver side swivels for transits Mk7, but I was told by a local motorhome dealer it was something to do with the handbrake fouling (which is a poor excuse as the chausson welcome has FASPs factory fitted on both seats in the transit cab!)
Mark
