Fitting of a Thule/Fiamma Awning (1 Viewer)
Jun 6, 2012
1,141
1,545
Leeds
Just after a bit of information from anyone who has fitted an awning to their MH or had reason to remove one.
Correct me if I'm wrong but looks like the brackets bolt through the MH body and then the actual awning box is then located into said brackets and screwed into place?
The reason I ask is I'm wanting to remove the awning box from the MH to do a couple of jobs but not remove the brackets if that makes sense?
Can anyone who has any knowledge please advise.
Cheers David.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Yes David there will be a few screws "Omnistor "(self tappers) inside the awning box and it will then un hook from the brackets. You will need at least two people on a van your size.
Fiamma often have screws on the outside of the box on bottom edge and same applies
Techno
Jul 28, 2010
15,475
20,756
May 2010
Typical of Thule/Omnistor
rapido-789-series-awning-mount-jpg.70612
Sep 21, 2013
226
241
Isle of Wight
since Apr 2013
Its far easier than you'd think. On my Fiamma there were 3 small bolts that held it in place to the bottom of the bracket and then it just twisted forward pushed up and it was off. It seems unsafe from this description but when you try it its very well designed and safe
Nov 30, 2009
6,548
149,013
Pickering
PVC the PUG
Our panel van had 3 lugs already on the roof. So no drilling into the shell.
I fixed the mounting brackets to the lugs using sikaflex and supplied bolts . Then fix the awning to the mounting plates. Simple.
But I needed a lift , off my lad, with 4 metre awning . You couldn't do it by yourself.
dpsuk999
Jun 6, 2012
1,141
1,545
Leeds
Thanks guys, it did look like you just unscrewed the screws at the base of the brackets but I didn't think that would be very secure so I'll have a go at the weekend.
Cheers David
