Fitted air-suspension (4 Viewers)
Steve and Lou
19
13
West Sussex
Coach built
Getting more experienced each trip
hi all
Fitted air-suspension last night and have a question for those of you who use it.
Do you let the pressure out when you are not using the van or leave it pumped up?
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
I was advised to leave at least 2bar, otherwise the bellows could split
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
hi all
Hi thinking of having it fitted to my autotrail was it expensive?
Flamenca
1,266
804
Europe
Hymer 564
The data for my air suspension states that you must have at least 1 bar at all times. I leave mine at my 'normal' running pressure.
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Cannot see the point in letting it down, you only have to pump it back up next time.
Minimum Dunlop recommend is 1 bar and I can see that, as to remove all air would allow the bellows to collapse and rest on each other, and if left for some time could they stick together?
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
I leave our VB air suspension inflated, and instructions say not to drive under .5 bar.
On our last van I fitted Dunlop A/S from Marcle leisure and the instructions said that you must release air pressure if jacking vehicle up at the rear.
The instructions with our VB suspension doesn't mention this.
John.
11,956
16,570
John.
It would make sense to do so otherwise the air bags may over-extend. Assuming you're jacking the body rather than the axle of course.
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
I fitted it myself and it cost £440.00 with compressor and gauges from TL TECH
Same here (except from Marcle) - a really easy job (as long as fit, healthy and can crawl around under Moho) and interesting too. Works superb on our Autotrail Apache 700 - instant benefits all round.
Don't think I could go back to one without it. Shame you're in Halifax, if you were down this way I would do it for you.(y)
Leave ours at running pressure between trips but drop it down to about 2 bar when laid up. Agree, if jacking don't let axle weight 'hang' on air bags/spring travel.
Regards,
Trikeman.;)
jollyrodger
6,282
26,425
Devon/Cornwall
'Obby
Since 1968'ish
I have the Goldschmidt system with onboard compressor already fitted(8 months before) when I bought the van and usually leave it minimum 2 bar then when the m/bike goes on the back ,put it up to 3.5bar quite a cumfy ride at that :)
haganap
12,760
26,462
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
I fitted mine at the weekend. It was really easy to fit even to the mercedes chasis. I had at least 3 funsters offering advice @drago35uk @Ockerron and @mitzimad all of them laying on their backs doing various things whilst I looked at it.
What amazed me was the difference on the way home, much stiffer ride home really good and well impressed. Mine are from the Czhek repulic, £259 for the full kit, no compressor but you don't need one, blow it up and leave it. ;)
any one want's advice on fitting, ask away. I'm an expert on the subject:mad::pinocchio:
May 16, 2014
817
1,063
Ammanford
Dethleffs Trend
since May 2014
Never had it less than 1.5 bar since we have had the van (though that is only a little over a year). No plans to lay it up for more than a fortnight so that issue, hopefully, will not arise.
Aug 19, 2007
560
242
Birmingham
looking
Paul do you have a link for where yours is from, also did you sort your stairs out?
Karl
haganap
12,760
26,462
planet earth
Yes Karl, Stairs all done, I project managed it myself just got nikki finishing the decoration. ..mine were from eBay
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
[QUOTintrested were did you wire the compressor into?="Trikeman, post: 1529410, member: 22516"]Same here (except from Marcle) - a really easy job (as long as fit, healthy and can crawl around under Moho) and interesting too. Works superb on our Autotrail Apache 700 - instant benefits all round.
Regards,
Trikeman.;)[/QUOTE]
Very I
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
1532316, member: 29917"][QUOTintrested were did you wire the compressor into?="Trikeman, post: 1529410, member: 22516"]Same here (except from Marcle) - a really easy job (as long as fit, healthy and can crawl around under Moho) and interesting too. Works superb on our Autotrail Apache 700 - instant benefits all round.
Hi very intrested were did you wire the compressor into?
also did you fit the compressor under the seat.
looked at the site but there pitctures are not very good.
Regards,
Trikeman.;)[/QUOTE]
Very I[/QUOTE]
Hi somthing went wro
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
Were did you pick up your wiring was there some under the seat?
did you fit the compressor under the seat also.
