Fitted air-suspension
Discussion in 'Tech/Mech General' started by Steve and Lou, Aug 26, 2015.
  1. Steve and Lou
    Steve and Lou Funster
    Apr 22, 2015
    19
    13
    West Sussex
    hi all
    Fitted air-suspension last night and have a question for those of you who use it.
    Do you let the pressure out when you are not using the van or leave it pumped up?
  2. grasscutter
    grasscutter Funster Life Member
    Oct 11, 2009
    1,361
    2,261
    East Wittering. West Sussex.
    Leave it pumped up.(y)
  3. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,508
    1,636
    Stretford
    I was advised to leave at least 2bar, otherwise the bellows could split
  4. laurieash
    laurieash Funster
    Jan 29, 2014
    569
    320
    HALIFAX
    Hi thinking of having it fitted to my autotrail was it expensive?
  5. Flamenca
    Flamenca Funster Life Member
    Jun 21, 2013
    763
    460
    Cornwall/France/Spain
    The data for my air suspension states that you must have at least 1 bar at all times. I leave mine at my 'normal' running pressure.
  6. keith
    keith Funster
    Aug 25, 2007
    3,277
    1,652
    Ecclefechan
    Cannot see the point in letting it down, you only have to pump it back up next time.
    Minimum Dunlop recommend is 1 bar and I can see that, as to remove all air would allow the bellows to collapse and rest on each other, and if left for some time could they stick together?
  7. Steve and Lou
    Apr 22, 2015
    19
    13
    West Sussex
    I fitted it myself and it cost £440.00 with compressor and gauges from TL TECH
  8. Neckender
    Neckender Funster
    Oct 15, 2007
    1,050
    1,305
    Stoke on Trent or Benidorm
    I leave our VB air suspension inflated, and instructions say not to drive under .5 bar.
    On our last van I fitted Dunlop A/S from Marcle leisure and the instructions said that you must release air pressure if jacking vehicle up at the rear.
    The instructions with our VB suspension doesn't mention this.
    John.
  9. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,959
    2,784
    Kendal, Cumbria
    It would make sense to do so otherwise the air bags may over-extend. Assuming you're jacking the body rather than the axle of course.
    • Like Like x 1
  10. Trikeman
    Trikeman Read Only Funster
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Same here (except from Marcle) - a really easy job (as long as fit, healthy and can crawl around under Moho) and interesting too. Works superb on our Autotrail Apache 700 - instant benefits all round.
    Don't think I could go back to one without it. Shame you're in Halifax, if you were down this way I would do it for you.(y)
    Leave ours at running pressure between trips but drop it down to about 2 bar when laid up. Agree, if jacking don't let axle weight 'hang' on air bags/spring travel.
    Regards,
    Trikeman.;)
  11. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,557
    7,064
    Plymouth
    I have the Goldschmidt system with onboard compressor already fitted(8 months before) when I bought the van and usually leave it minimum 2 bar then when the m/bike goes on the back ,put it up to 3.5bar quite a cumfy ride at that :)
  12. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,130
    13,879
    Heavan
    I fitted mine at the weekend. It was really easy to fit even to the mercedes chasis. I had at least 3 funsters offering advice @drago35uk @Ockerron and @mitzimad all of them laying on their backs doing various things whilst I looked at it.
    What amazed me was the difference on the way home, much stiffer ride home really good and well impressed. Mine are from the Czhek repulic, £259 for the full kit, no compressor but you don't need one, blow it up and leave it. ;)
    any one want's advice on fitting, ask away. I'm an expert on the subject:mad::pinocchio:
    • Like Like x 1
  13. mpdcymru
    mpdcymru Funster
    May 16, 2014
    357
    443
    Ammanford
    Never had it less than 1.5 bar since we have had the van (though that is only a little over a year). No plans to lay it up for more than a fortnight so that issue, hopefully, will not arise.
  14. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,048
    3,450
    walthamstow east london
    If jacking the rear up can damage the bags they should come with check straps
  15. chippy63
    chippy63 Funster
    Aug 19, 2007
    261
    149
    Birmingham
    Paul do you have a link for where yours is from, also did you sort your stairs out?
    Karl
    • Like Like x 1
  16. haganap
    Dec 5, 2007
    11,130
    13,879
    Heavan
    • Like Like x 1
  17. laurieash
    laurieash Funster
    Jan 29, 2014
    569
    320
    HALIFAX
    [QUOTintrested were did you wire the compressor into?="Trikeman, post: 1529410, member: 22516"]Same here (except from Marcle) - a really easy job (as long as fit, healthy and can crawl around under Moho) and interesting too. Works superb on our Autotrail Apache 700 - instant benefits all round.
    Regards,
    Trikeman.;)[/QUOTE]
    Very I
  18. laurieash
    laurieash Funster
    Jan 29, 2014
    569
    320
    HALIFAX
    1532316, member: 29917"][QUOTintrested were did you wire the compressor into?="Trikeman, post: 1529410, member: 22516"]Same here (except from Marcle) - a really easy job (as long as fit, healthy and can crawl around under Moho) and interesting too. Works superb on our Autotrail Apache 700 - instant benefits all round.
    Hi very intrested were did you wire the compressor into?
    also did you fit the compressor under the seat.
    looked at the site but there pitctures are not very good.
    Regards,
    Trikeman.;)[/QUOTE]
    Very I[/QUOTE]
    Hi somthing went wro
    • Like Like x 1
  19. laurieash
    laurieash Funster
    Jan 29, 2014
    569
    320
    HALIFAX
    My reply has got mixed in with the above post.
  20. laurieash
    laurieash Funster
    Jan 29, 2014
    569
    320
    HALIFAX
    Were did you pick up your wiring was there some under the seat?
    did you fit the compressor under the seat also.
