Filling up the water tank - 'how hard can it be?', I thought...
Discussion in 'The Beginner' started by streetdaddy, May 16, 2011.
  1. streetdaddy
    streetdaddy Read Only Funster
    Mar 13, 2011
    38
    London
    I have a 1998 Elddis Autostratus 5-berth coach built. I tried to fill up the water tank for the first time recently and the water just comes straight back out of the hose that is under the motorhome near the tank...
    Am I supposed to block this hose, or is there some other lever or tap that I don't know about?
    Feel like a bit of a doofus! :Doh:
  2. peter H
    peter H Funster Life Member
    Jan 18, 2008
    1,350
    662
    Neath, South Wales
    Sounds like the water dump valve is open or possibly the manual drain plug in the bottom of the storage tank is open.
    Sorry don't know where the auto dump valve is, but someone on here will.
    Peter
  3. RonnieJ
    RonnieJ Read Only Funster
    Jun 30, 2009
    111
    74
    Thetford, Norfolk
    Drain tap is open some have a tap some have a plug.
  4. movan
    movan Funster Life Member
    Dec 2, 2009
    14,224
    26,006
    Moving around
    Don't know if it is the same as the Eldiss Autocirruss, but mine is in the wardrobe.... a removable floor. Remove it and go down it head first :Eek!: and lift up the flap tap. That means it is open. Close it push down the flap.. Don't fall in the hole.:Smile:
    • Like it Like it x 2
  5. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Lift the seat base that backs onto the drivers' seat.
    You will see a black tank - the water tank.
    Gurning you face against the wall, reach your hand down between the wall and the tank.
    At the bottom, nearest your leg as it were you will feel a tap - can be quite tight, turn 180 degrees and that will be off.:thumb:
  6. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    Sounds about as easy as pulling the drain plug out on our LMC-but at least you dont have to strip to the waste and plunge your arm up to the armpit in cold water :BigGrin:
    Mike.
  7. davejen
    davejen Funster
    Aug 21, 2008
    1,267
    722
    Kirkpatrick Fleming Dumfries
    Could be the dump valve on the water heater if it has been left open after draining down. Happened to me once!
    Cheers, Dave:thumb:
  8. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,677
    14,525
    North Lincolnshire
    Sounds VERY unladylike!
  9. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,677
    14,525
    North Lincolnshire
    My drain tap is by the water pump. Check for a simple tap there, at the side going away from the pump.
    It will be obvious what it is, no other reason for a tap to be there.
  10. rainbow chasers
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    We have one, same model, which is up for 'retirement' this year -( as soon as it has had it's 3 year windows out re-seal and finished this season anyway!)
    I had a job finding the drain - not the best place in the world!
  11. streetdaddy
    Mar 13, 2011
    38
    London
    cheers, that was it! doh :Doh:
  12. Gooney
    Gooney Funster
    Jun 2, 2010
    4,774
    7,871
    Flintshire
    As Terry Wogan used to say on his radio show "Blindfold the budgie":Laughing:
