Fiat to Drop 3.0 Litre Engine? (1 Viewer)
Sep 10, 2013
1,187
18,697
Chelmsford Essex
Getting better
With the political pressure mounting regarding Nox levels in our cities we all need to brace ourselves for change. The rush to diesel is over and shown to be a blind alley visited by the Europeans. The Japanese and Americans where not taken in and stuck with gasoline. Yes diesel produces lower CO2,but it is now shown to kill some of us as well. Cars will move towards petrol and hybrids, vans like ours will probably still use diesel but smaller engines with loads of clean up kit and restrictions on inner city use.
Change is coming and will be problematic for all, nothing is easy anymore.
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Pendine is just along the coast from us - might be worth a day out :)
We were there last week but unfortunately Babs was away being prepared for tomorrow ... I considered staying another week but had to get home:cry: ... still I will probably hear it here in Norfolk.:rolleyes:
Jul 29, 2013
9,071
18,521
Salisbury
Hymer B678DL A class
since 2011
Our Exis has 2.3 150 Euro5 engine and has plenty of torque and powerful enough for towing it runs alon really smoothly probably need to use the gears slightly more when towing but that's to be expected.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Fiat started of with the right idea with the Beast of Turin, but seem to have lost there way in later years. An early Fiat engine once held the record for the fastest thing on earth over a flying mile.
DBK
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
I ment the new Fiat not Babs
There is only one Babs...
Abacist
3,733
10,691
Devon
N & B Arto 88F Tag
since 2013
Did I see that the new engine is only rated for 4.4 ton loads? What about all the tag axle vans rated above this? Are Fiat limiting their market? Doesn't seem to make any sense!
Jul 27, 2010
704
1,452
Farnham Surrey
Bilbos Nexa
on and off since 1980
It may well be the case, most complaints about remapping seem to be clutch failure on tag axle vans.
Reactions: DBK
icantremember
8,333
17,545
Hymer T-SL668
since 2005
If true it reflects what a number of other manufacturers are doing - making smaller more efficient engines with the same power output as their larger predecessors.
It certainly seems it's the way things are going .......
My son recently bought a new Volvo V40 with 2.0 litre engine and aparently Volvo cars have a choice of petrol or diesel engines but ALL ranges are now only 2.0 litre with extra power gained from single or twin turbos.
Zepp
1,673
3,260
Roaming
7 Years
Just rang a carthago dealer in the UK I was told I could only have the carthago chic on a 2.30 180bhp not doing 3.0 anymore may have to start looking for a merc or look for older stock.
Paul
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
I recollect as a young boy seeing a Gardner Engine being started up and running whilst out of a "Lorry" on the ground to prove it was all good to te chap looking to buy it.
In the days when I was exporting them, the buyers would often come and pick a couple to be started on the ground before payment. I never had one that would not start, even those with the odd piston missing would fire up :whistle:. I am still contacted now for the supply of old Gardners, alas the heyday has gone :(.
Jan 13, 2014
3,601
11,581
Leeds - Yorkshire
Its just nice to reminisce you mentioned Gardeners and my mind went back to that day, I doubt anyone under 60ish would believe that this sort of thing was done and quite normal.
Jul 29, 2007
6,551
39,656
Ipswich
RV and PVC
30 years
Just stick a Ford 2.3 ecoboost in them, more power, more torque, more m.p.g. & similar / less NOx emissions & less P.M. - job done :)
LPG is the answer, mot results from my 8.1L CO. Limit 3.50% actual 0.00 HC. Limit 1200ppm actual 260ppm
Zepp
1,673
3,260
Roaming
7 Years
I don't think so just seen the new Hymer 2017 models
Specifications
Type New
Manufacturer Hymer
Range B Class Premium Line
Model B 778 PL
Year 2017
Class Integrated
Length 8.58m
Weight 5,000kgs
Berths 4 berths
Chassis layout Right hand drive
Chassis make Fiat Alko Tag axle
Engine Fiat 2.3 180hp (Euro 6)
Floorplan Single beds over garage with large lounge
Transmission Automatic
Seatbelts 4
Aug 27, 2009
19,788
23,069
Hertfordshire
Van Conversion
40 years
It looks as if Fiat may be about to discontinue the 3.0 litre engine in favour of a 2.3 litre unit with the same power output. The Fiat website still shows a 3.0 engine but it is described as Euro 5+ but the new Euro 6 engine may not come in this size.
If true it reflects what a number of other manufacturers are doing - making smaller more efficient engines with the same power output as their larger predecessors. Ford were one of the first taking this route I think.
WV too they replaced the 2.5 to a 2.0ltr with a common rail system had more bhp and better everything else.
Reactions: DBK
4
44658
Don't forget that most fairgrounds are powered by Gardner engines for their generators, clocked several million miles, if on the road.
ambulancekidd
Sep 23, 2014
10,369
28,396
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
jessthedog
979
8,670
south east
A
The parent company IVECO are still producing a Euro 6 3.0L which produces 205hp. Maybe not needed in all but the largest motorhomes.
Ford Euro 6 are now 2.0L and it looks like Peugeot and Citroen will use them.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
205 hp from a 3 litre engine. Its not so long ago I used to drag well over 32 tons around with less hp than that from a 10 litre engine. Mind you, they were good for over a million miles before you had to put a spanner on em.
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
I remember long ago when my mate brought his first tipper, it was a foden 180 gardener and his comments was I spend all day changing gear and it's slow
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Aha, but the captain of a Chinese junk thought he had a speedboat once one was fitted. None of that waiting around for the wind to blow :).
jessthedog
979
8,670
south east
A
I bet the V10 was nice and quiet too??? I said, I bet the V10 was nice and quiet too??:LOL::LOL:
The Ford Euro 6 2.0L produces 168hp with 405Nm. against the Fiat 2.3 at 180hp with 400Nm.
These new diesel engines certainly pack a punch for small units. In 10 years time it could be a 1 litre engine producing the same output?
