- Jul 5, 2013
- 11,727
- 13,706
- A class
- Since 2013
OK so just back from the Fiat Pro dealer who has flashed the new software. As others have said this now means the instrument lights are on whenever you switch on the ignition.
Not over impressed with light level as I was driving back so I have just has a play around once I got home. It turns out that you can adjust the light level. Turn ignition key to first position (not full on) and press Mode button briefly and a menu will come up on the display. You can scroll up and down using the headlight up and down buttons. Choose Dimmer and up will come a display showing the light level - mine was 2 stops away from maximum so I put it onto maximum and it is now much better.
BTW if you repeat the above sequence with the lights on then you can adjust the brightness set for night time. That was the only adjustment mentioned in the handbook, but doing it without the lights on now works as well. So must have changed that in the software too.
