Steve N Tracy
I had mine done about 3 months ago its great for driving under trees, but useless any other time.
Good luck with that ... it took years to get them to fix the gearbox issue ... remember 'juddergate'????I've heard back from Fiat Proffessional who say they can do no more. I have told them they must rethink given that these vehicles are illegal if owners/drivers cannot read what speed they are travelling at.
Perhaps we need to invite owners to sign up to a presentation to Fiat that they MUST take some action to resolve this issue ?????
Just picked up the MH from FIAT after having the radio replaced and the upgrade to have the dash lights on when the DRL are on. Its a reasonably sunny day today and it does make a difference, although not as good as the VW you can definitely see the speedo now much better so I guess it has worked for me. Will see what its like when we are next out in it as only drove it back to the storage yard and see what its like in different weather conditions.
If you want to know the truth I haven't noticed a problem with my van and am blind in one eye with a contact lense in the otherI expect my new van has this issue. if so I will look at installing a strip of LEDs in the binacle
No need to install a strip. Look what one will do. Took 12V off the dashcam plug by fitting a small external connector to it and took the wire behind the underdash plastic. A bit of Blu-Tac on the steering column and Bob's your father's brother! I only had a green LED but as a first try it's better than nothing. White ones are available also. I reckon less than a pound an an hour or so's work. Maybe put one for the tachy as well.I expect my new van has this issue. if so I will look at installing a strip of LEDs in the binacle
So it is just a light pointing from outside!See the little white/blue blob under the speedo. It's a blob of blutac and sits on the steering column cover just in front of the steering wheel.
My satnav is built in and does not display speed! At least I've not found a way of making it show it. It tells me if I've gone over the speed limit but not my actual speed. Its a Zetec all in one media centre thingy so if anyone knows how to persuade it to show speed please let me know!I now use my Sat Nav to check my speed rather than the speedo.
