Fiat Ducato 2.5 5th gear Lubrication Tip (2 Viewers)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
I dont know if this has been posted before, however, if it has, I crave your forgiveness. :)
The mechanic at my local garage was a fitter for Fiat. He has told me that removing the gearbox dipstick, measuring 20mm from where the stick comes out of its holder sleeve, and then marking with a junior hacksaw, will increase the gearbox oil capacity by some 60 ml once topped up to this level. No detriment to seals, says he. Apparently, this mod was issued to all FIAT agencies some time ago, and will reduce the occurrences of 5th gear failure, by ensuring a better oil splash effect.
Not sure about other Fiat gearboxes with the same problem, he couldn't remember if it covered them all, however, he did say that they all pretty much conform to the 2.5 box.
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Here is a photo of what I mean, reproduced from the public domain.
Arrow pointing to the new mark.
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Mine has John, even though it is a bitch to find. I thought they all had them.
PP Bear
7,807
28,782
Kent, UK
Auto Trail Dakota SE
Blimey, there's a dip stick on the gearbox :cool:
Where where where is it located (and yes I know the gearbox) but any pictures or ideas.
I have the 2006 Autotrail with the 2.8JTD and 5 speed manual :)
Thanks in advance Funsters
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
The best cure I found was not putting it into 5th until the engine had fully warmed up or at least 20 miles. 5th gear is very high and does not get a lot of oil, especially when the oil is thick due to being cold. All 2.5 diesels both turbo and non turbo had a dipstick on top of the box, its just to the right of the speado cable but am not sure about the 2.8 models. The gearbox has 2 chambers as 5th was an afterthought by Fiat. The best way to fill the box is remove the reversing light switch and fill the box through the hole. This will make sure both chambers are full.
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Am now using semi-synthetic gear oil, much smoother change.
43,331
49,468
To be honest, mine probably did...but gearboxs used to be a fill and forget item, unless they sprung a leak, with a combined fill and level plug.
Never even gave a thought to it having a dipstick.....they were always the domain of auto boxs.
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Here you go. This is looking from the underneath, front LH side. 1 is the dipstick, 3 & 3 the drain plugs (2.5 TD)Broken Link Removed
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
I would also recommend semi synthetic. Another problem is water contamination, due to the position of the heater vent and also running down the scuttle. It finds its way into the box via the dipstick or reversing light switch. Make sure the dipstick is a good fit and if possible make some form of cap from the top of an airosol.
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
I dont seem to get that problem Checked it today, no contamination or emulsification on the dip stick.
43,331
49,468
Or fit the upgraded scuttle drain tube.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Only ducatos on the old Talbot Express shape body had dipsticks on the gearbox. Express shape died out in '94 to be replaced by Mk2 (X230) Ducato/Boxer/Relay which ran till 2001/2 when the facelifted variant was brought in (X244), this version ran till late 2006 when the (X250) shape came in.
D.
Rob and Val
1,906
2,677
Talbot Compass Calypso
Since July 2010
We have a 1994 TE with a Peugeot 2.5 non turbo engine. We were having problems with changing up to 5th gear. Our trusty mechanic did the alteration that Tootles suggests above. Result ... a much smoother gear change.
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
There you go!! I'm not totally useless after all!! (y)(y)
ArcticKris
147
42
North Norway
Kabe Travel Master i910 Q
Since 1990
Great topic,Thanks to Tootles for this,out of interest we use only synthetic oils in our cars,MH and equipment,we find it a lot easier on machinery in our very cold winters,talking - 35/40 in January
Kris
Vespita
5
15
Hallo
Just did the some on my Ducato from 1992, before something more serious hapandes.
Many thanks from the tips that I learned and I special thanks to Tootles
Thank You.
Here with the oil
I aplied regural mineral 80w90 and put an adictive to help the changing the gears from STP. Here were I live in Portugal didn´t find a syntetic 80w90 oil.
Best regards
Feb 21, 2016
4,920
29,552
Uk
Since 2017
Can anyone say for sure whether the 2.8JTD (2006) 5 speed, has a dipstick please?
If the answer is..no,I will try to top up through the reverse gear switch,but haven't got a clue where that is.......help please!
Thanks.
Feb 21, 2016
4,920
29,552
Uk
Since 2017
Do these pictures help.
Fill up through the breather on the 2.8JTD.
Also look on YouTube as lots of help there too:)
View attachment 187768 View attachment 187769 View attachment 187770 View attachment 187771
Great help,thanks PP Bear,I'll take a look in the morning.Never really understand it when gearboxes are "filled for life" seems a silly thing to me,but then I'm from the time when you changed the engine oil every 3000 miles,as well,as the gearbox and rear axle regularly.
I'll take a look at that new fangled U tube thingy too!
Thanks again.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Thanks.
Podney, by 2006 the gearbox was totally different to previous versions. It will not need topping up unless there is a leak, if there is a leak then that needs sorting out first.
D.
Emmit
8,034
17,753
Pilote Explorateur
Jan.2014
D.
Unless you own a Hobby who seemed to have an inexhaustible supply of X244 2.8's that didn't see the light of a DVLA Reg Plate until September 2007:whistle: I know, we have one.
Jan 29, 2017
685
558
Gloucestershire
Lunar Champ H621
15yrs
Whilst your down there...
I was advised and I think its standard policy now, to overfill the box by an extra amount as the 5th gear is (on our 2005) is only splash lubricated. For that reason I try hard not to load the 5th gear until the engine is fully up to temperature. The other thing is that the scuttle drain pipe has a habit of dumping its waste water onto the gearbox breather! and also this affects the gearchange linkage at the bottom, so this needs to be kept oily. At least thats what my very experienced van garage told me.
So far (777000m) no problems
Mike & Ann
sorry that should be only 77,000 miles!
Oct 2, 2008
4,471
7,957
Salopia
Duro 6x6 Overlander
since 1968
The other thing I would highly recommend is to fill with a full synthetic oil . RED LINE OILS do all kinds of gear oils . It is not cheap but is a major improvement . Proved their oils in the extremes of Australia . I have no involvement with Red line other than as a user and also sold and installed it in Australia.
Nov 18, 2011
11,862
43,044
Planet Earth
A van
Over 25 year's
To fill my gear box I filled it through the reverse switch
I used a pressure brake bleeder to pump the gear oil in this is a old one I use just for that job it works well
Bill
Silas
120
114
Stafford
Kontiki
One month
Can I just be clear about this, you are putting less oil in the gearbox?
