faulty fridge
Discussion in 'Bessacarr' started by theresa, Feb 28, 2010.
  1. theresa
    theresa Read Only Funster
    Mar 9, 2008
    367
    near falmouth cornwall
    we have a N180 fridge that has died on us (great):cry: fault14 comes up on the display, in the handbook it says this means display board and power board lost communicatin. we are in spain at the moment and its warm here so really need the fridge , hopeing to find a thetford agent near here , we are at bonterra park in benicassim. has anyone on here had this fault , any advice guys please :Blush:
  2. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,780
    6,047
    Mansfield,Notts
    Could be, and sounds like a simple loose connection between the two:thumb:
    It could of course also mean one or other of the boards have past away:cry:
    Geo
  4. theresa
    Mar 9, 2008
    367
  5. jhorsf
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    your welcome Theresa:thumb:
  6. jhorsf
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
  7. theresa
    Mar 9, 2008
    367
  8. jhorsf
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    good luck with the repair when you have had it done post on here what the problem was it may help someone.Silly question but I have read with Swift problems with battery charger/12 volt system can give fault 14 so check 12 volt system a good idea perhaps
  9. theresa
    Mar 9, 2008
    367
    yes over half did check 12volt system and it was o,k , the fridge was on gas when it went wrong , will post when ,and if its fixed tomorrow , going to cook some deforsted bugers and chips now lol :Blush: oh and runny icecream for after
  10. bailey
    bailey
    Jan 18, 2010
    541
    138
    Airdrie Scotland
    Thetford Fridge
    Fault 14 is as you say communication breakdown between boards which will have to be replaced to do this the fridge will have to come out as you cant access from the vents
    Bill :thumb:
  11. Supertractorman
    Supertractorman Read Only Funster
    Sep 7, 2007
    415
    3
    My fridge stopped working on gas, put it on electric then 12v, and it worked OK, so disconnected gas cylinder which still had good pressure, but connected to new cylinder and it started to work. Just wonder if there was an air lock on gas line as have had no problem since and used the old cylinder of gas later.
  12. theresa
    Mar 9, 2008
    367
    this daft fridge is a all singing all danceing thing (which is not working:Doh:) and i cant select anything , not like the one in our old van where you just turn a knob to the setting you want like gas 12v or mains , its all done with one button , wish it was just a simple thing like a air lock in the gas line , i think that one of the boards has gone wrong , there maybe one in the top of the door ,where the display panel is . how they will take the fridge out if not ,god only knows :cry:darn thing is so big:Eeek:
  13. theresa
    Mar 9, 2008
    367
    well just had the fridge fixed , they had to slide the fridge out and a wire had come out of a connector that is under the fridge , so we are all up and running again . thanks to coach graft leisure at scorrier . :thumb::thumb: first class service from them :thumb:
  14. walburga
    walburga Funster
    Aug 20, 2007
    300
    99
    Leyland
    We could've saved you all that messing about carrying ice from Lidl every day.
    Me, Barry, & Eric had an axe and a jemmy. It would've been out in a jiffy while Joe was on his back under the van friggin the waste valve.
    You & Eileen (guarded by Rusty & his german pals from next door) could've been gassing & supping gallons of tea while we wrecked / fixed the fridge !
    Anyway, glad you got back and all is ok.
    Allen & Eileen
  15. iceni
    iceni Read Only Funster
    Dec 3, 2007
    301
    115
    Birmingham
    if you have the underseat power supply box for the mains make sure someone hasnt stowed stuff in the locker and knocked one of the rocker switches off.
    Phill
