Extra leisure battery (1 Viewer)
Melvin
230
182
Coach built
On & off since 1974
I want to fit an extra leisure battery ,my existing battery is a 100-110Ah Banner on a 2016 reg van .I know I shouldn't mix old and new but I was hoping to get away with it.
Should I go for the same make as fitted or is there another make that's better value for money as some of reviews I've read on Banner are not very encouraging.
Feb 24, 2013
13,110
101,579
Bolsover, Derbyshire
Hymer S800
not long enough
Or maybe do nothing, I have recently had issues with not enough volts, we already have 2 batteries and was considering changing them both again (did 4 years ago when we bought this MH)
Just been down to Vanbitz for an alarm and they very kindly looked at my batteries, turns out one of the 2 was failing / virtually failed, which then dragged my one good battery down with it. They removed the duff one we are now back to a single battery
Just had first night in France, so have done quite a few miles which will keep it topped up, but also had Alde on overnight as it was 0C outside, set stat at 16C so that cut in quite a bit overnight
Woke up on grey day definitely no solar input to more volts than we normally have and my laptop had been charged via my little 150W inverter, all looking good so far on one battery (y)(y)
bit to go to be totally convinced, but we are away for 18 nights, 50/50 site / aires so will monitor carefully :)
53,701
151,012
As it is less than a year old should be fine fitting another one, I wouldn't get another Banner as myself and other Funsters have found they are rubbish. Go for a Varta or Exide if you want a decent battery.
53,701
151,012
Good point(y)
I was going to up grade mine from 1 90AH to 2 110 AH, but I checked my electroblock and it is a max 180 AH, so can only go 2 x 90 AH.
You are supposed to factor the starter battery into the equation as well 2 x 90 A/H leisure batteries plus a 90AH starter battery is 270A/H but you can allow a bit of leeway as the starter battery charging current is limited to between 2 - 6 amps depending on the model of Electroblock.
Also depends on how you use your system, in theory you would only overload the Elektroblock if all 3 batteries were flat, so under normal use providing you are aware of the limitations there is unlikely to be any problem with 2 x 110A/H leisure batteries. If like me you rarely use EHU and rely on solar as your main charger the load on the Elektroblock is not that relevant.
glastry
395
357
northern ireland and portugal
a class s550
And while on the subject,would it not make sense to fit one new larger capacity battery?
Particularly in an older van with limited space,I had thought about a 160 or 180 ah battery to store more power?
Feb 9, 2008
8,955
18,710
Corby, Northants
Coach Built
Are you sure that is correct ! On my Autotrail the leisure and cab batteries are never all on charge at the same time. The charger is either charging one set or the other. My manual clearly states maximum capacity of 220 HA charging capacity.
53,701
151,012
If you are worried about overloading the Elektroblock the add-on 18A charger unit which doubles the rating is only £130 and just plugs in.
53,701
151,012
Yes, Schaudt who make Elektroblocks state you must take into account the starter battery when calculating the size of the battery bank. In practice no one ever does.
