External gas fill point for refillable system. (2 Viewers)
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
I shall be fitting a refillable gas system sometime soon (not sure which one yet) and was wondering about which side to fit the refill point. Same side as gas locker or same side as deisel fill point. They are on opposite sides on my Burstner. I do have a suitable area of "skirt" below the gas locker to fit the refill point into. That's where I plan to put it anyway, but just wondered what other people's experience was.
Also, the skirt in question is aluminium and has a single bracing bracket. How heavy are the fill guns and will there be any problems with the fill point being so near the ground (probably about 12 -15 inches from). I intend to add another bracing bar.
With the above in mind is there a chance that there may be some offers on refillable systems at Peterborough? Anyone get theirs from a show at an attractive price?
GJH
29,450
38,827
None, now sold
2006 to 2022
I've taken a couple of photos of our (Burstner t625 Harmony) gas locker and Alugas filler, installed in the locker wall, one with the locker door closed and one with it open. It's a comfortable height for using the gun, solid with no need for bracing, and no need to run long pipes to the bottles.
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Our last van it was the opposite side from the diesel filler this van it's the same, I would fit it on the side that's the easiest as unlikely you'll fill up at the same time .
Reactions: kip
Xabia
1,186
821
Since 1996
I fitted mine near the gas cupboard which just happens to be on the opposite side of the motorhome, didn't fancy a long pipe from the other side. No problems really, just filled at a Repsol station where the gas supply was on the opposite side so just moved over when diesel fill completed.
The guns are reasonably heavy so I fitted a bracing strap, using Sikaflexed. To the alloy side panel, it's as solid as a rock. The height you quote won't be a problem.
My system is Gaslow, easy to fit and excellent company to deal with.
Mike
sdc77
3,244
4,550
Weardale, Co Durham
Mike
Ours is the same... but gasit
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
View attachment 99934 View attachment 99935
Where does that vent to Graham? in the event of a leak at the rear of the filler?
Im sure you will have got it right and it's vented to the outside some how, just checking for you and yours safety(y)
Geo
GJH
29,450
38,827
None, now sold
2006 to 2022
Geo
It's installed in the gas locker wall, Geo, so all the pipework is contained within the gas locker which was, of course, vented properly already.
The job was done by Dave Newell so it's right, alright (y)
JJ
Mágica
May 1, 2008
19,259
48,056
Burstner Privilege T
over 50 years
Gas pump connector and hose are pretty heavy... My refilling points are fitted on sturdy parts of the vans.
JJ :cool:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Thats ok Graham I was only thinking of your dear wife, you can blow thasen up whenever;)
Reactions: J H
19,375
30,361
Ours is in the door!! Which isn't ideal, I didn't do it so take no blame. The problem is/was that it was piped with the gaslow stainless steel flexi pipe and repeated opening and closing of the gas locker door fractured the pipe and the first time we attempted to fill it up we ended up with a puddle of liquid gas under the van. Looking on the bright side it tested the sealing/venting of the gas locker and it passed.
It now has a proper flexi pipe on(y)
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
I used one in France today, very heavy, especially if the pipework from the pump is being supported by the inlet as well. If you put it in thin ally without bracing you may need some one to support the filler. Make sure they wear thick gloves just in case!
Camdoon
1,531
2,808
Adria Matrix Supreme
Filled up in Spain today for the first time and also filled with fuel at the same time for the first time in 3 years so would go for easiest side for fitting. Never used a UK site for both fuels at the same time as lpg providers are not the cheapest diesel providers near us.
Oct 19, 2013
450
736
East Yorkshire
Elddis Autoquest 115
Few years
Mine is fitted inside the gas locker but would like to move it to outside - has anyone got one fitted to an Elddis Autoquest? I don't know where it can go as there doesn't appear to be anywhere strong enough to hold it and the pump...
