Excellent Tip for EHU Cables (2 Viewers)
ludo
724
1,178
Since 1990
Here is an excellent tip for looking after EHU cables, not kept on a reel. :winky:
Using this method will stop those annoying tangles developing.:thumb:
[ame="http://www.youtube.com/watch?v=gjdYpyGh3zM"]How To Coil A Microphone Cable - YouTube[/ame]
C
Chockswahay
This really does work………we use this method for all cables, rope,etc since seeing a similar post a few months ago (from our leader?)
Thanks for raising it again
::bigsmile:
Jan 3, 2008
3,341
5,359
Pakefield, Lowestoft, Suffolk, UK
Looking
Tips
Good tip which I will use. I wonder if the guy has tips for leaving the heating off and staying warm in the house. He appears to have been getting ready for the next video about that since he already has his wooly hat on. ::bigsmile:::bigsmile:
mentaliss
654
306
Lancing
Not to put a dampener on the obvious good points shown BUT has anyone tried this one handed method using a 50ft orange hook up cable......pretty heavy, especially using one wrist action to hold the increasing weight as the cable is wound up:RollEyes:
17,636
43,373
been using the same method many years since being shown it in technical college. the advent of velcro ties has also be a godsend as you can keep the coil tight during storage. just never use a power cable whilst its still coiled up as it will produce enough heat to start a fire
i am amazed that so few people understand the basics and learn it from a youtube clip.
callumwa
4,110
4,480
Tyne & Wear, sometimes..
Not a problem....
Just make your loops bigger, there will then be less loops to hold, so it will be much lighter......:thumb::thumb:
:winky:
ludo
ludo
724
1,178
Since 1990
If you find this method too difficult or cumbersome try this:
Make the first loop and, using a velcro strap, (or similar), secure the end of the cable to the cable itself so that you have a fixed loop. Then, using the "hand over hand" method, roll the cable up all the way to the end. When you want to unwind the cable, for use, simply unwind it, "hand over hand" in the reverse way that you wound it up.
If you do this you will never have tangled cables again. :thumb:
JockandRita
11,469
150,325
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Storing the EHU cable can be done in the same manner Firefighters store rescue lines, when not bagged, ie, in a figure of eight.
Holding both male and female plugs in the left hand, with arms apart by about 3-4ft, gather the cable over the right arm, then the left arm, then the right, then the left, etc, etc, until you reach the last 4ft before the loop/bite at the middle of the cable. With the cable gathered on the right arm, let go of the plugs and remove your left arm, and wrap the loop twice, around the remained of the cable as it hangs from your right arm. Hold the loop with your right hand, and pull it through the coils, as they slide off your arm.
1. Not only does this method take seconds to complete, (especially in pouring rain), it also prevents a bunch of bas###ds (knots) developing, the next time you come to unravel the cable.
2. It also allows use of the cable without having to unravel it all, (especially if really close to the EHU), simply because it's not tightly reeled on a drum, and therefore won't overheat. :thumb:
I can't find a video that demonstates this method...............so you'll have to use your imagination, until the next time you are pitched next to me on EHU, whereupon I could give a practical demo. :roflmto:
Cheers for now,
Jock.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
[ame="http://www.youtube.com/watch?v=1FVxNZlNgDU"]How to roll up an extension cord... - YouTube[/ame]
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
[ame="http://www.youtube.com/watch?v=_Je9LmUTZMY"]Coil Extension Cord & Rope - Hanger Built In! - YouTube[/ame]
