emptying fresh water (2 Viewers)
dom
Hi there!
I'm a newbie to motorhoming, and have just bought a 115, i want to drain and refresh the fresh water and not too sure on how to go about it, any help?
thanks!
Douglas
2,835
400
South Wales,
Very often there is a bung in the bottom of the tank that is removed by putting your hand/arm in through the access hatch in the top of the tank, its possible that the bung can be a straight pull out or have a thread.
Good luck,
Doug...
chatter
3,689
937
cheshire
5th wheel
Hi and welcome to Fun
somewhere there will be a release tap to drop the water but if you put a bit more info on about your motorhome one of our more knowledgeable members could well have the same van and be able to tell you exact.
dazzer
1,620
102
In my house
Virtual RV!!
10 Years
simplest way is to run all the taps till the tank empties then refill :thumb:
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
Drain the fresh water tank as Doug says, either through your fresh water tank drain point or better still, fill you fresh water tank and add a sanitizor, I use half a cup of ordinary household bleach.
Allow it too settle for an hour or two and then flush your fresh water through your taps and shower etc. This will have the benifit of cleaning your pipes. Keep flushing through until all of the bleach has gone. You can smell and taste it so will know when its all gone.
Repeat if required.
Jim
:Smile:
D
dom
draining water
Thanks guys! will try this weekend and let you know!
GJH
29,450
38,827
None, now sold
2006 to 2022
You mentioned a "115" Dom but not the make. If it Elddis Autoquest or Compass Avantgarde you may find that the outlet is similar to ours on the Autoquest 110 - a hose ending in a tap clipped to the underside of the van.
Graham
movan
21,492
120,753
Moving around
Burstner
since07
Graham glad you mentioned that hose and didn't want to pinch someone else's thread, but when reversing off the ramps at last meet, my hose was hanging down and I ran over it and the whole thing snapped off.
I can't see where it should join the van at the top end of it without lying under the van completely or paying out more money at a garage.
If I don't put it back on yet, will the water just run out or could I have damaged something where it joins the van? Know I will have to put water down sink and see, but is it possible it will be running into van lining or something please.
GJH
29,450
38,827
None, now sold
2006 to 2022
Has it snapped off Joy or simply pulled off from the tank?
On our van both fresh water and grey water tanks have a stub onto which the hose is pushed and held in place with a Jubilee clip (may need some PTFE tape winding round the stub to make a good seal). Both outlets are below floor level so no chance of water running anywhere other than onto the ground.
I've replaced both hoses on our van and it is a fairly simple job but does mean lying on your back beside/slightly under the van (no need to get right under).
Replacement hose is available by the metre from caravan spares shops. It's easily cut to the right length with a hacksaw if you need to shorten it.
The only problem I encountered was replacing the tap. I couldn't find a tap like the original for love nor money but found that a garden water butt tap (which I obtained from Wilkinsons) does the job.
If it's your grey waste hose that's come off you could simply put a bucket underneath to catch the water until it's replaced. If it's the fresh water hose that's come off you need to replace before using the van again because otherwise you won't be able to fill up with fresh water.
Graham
In Edit:
Forgot to say that the hose is 28.5 mm diamater and there should be a sealing sleeve at each end (those also obtainable from caravan shops).
movan
21,492
120,753
Moving around
Burstner
since07
Hi Graham ... thank you for that. You are soooooooooo right. I can't find a bloomin tap to fit the end anywhere... they are all the wrong size. It looks like it snapped off at the van end but I ran over it..:Sad: so it is cracked. The tap fell off when I went over a bump beforehand..:Sad:
Thank you.
Feb 4, 2010
2,329
1,590
Mid. Glamorgan, S. Wales
Motorhutch / Toy Camper
:Sad:
Is this some kind of 'meet' tradition, because didn't you stress-test your external LED lights at the previous one by bouncing them down the road when you left? :RollEyes:
In case these things happen in threes.....may I suggest that all the Funsters do a pre-launch check of your van when you depart from Malvern? :roflmto:
Mixter
227
Keighley, West Yorkshire
Now a year - cant believe it!
Is this the tap someone is looking for? I believe without the back nut, it fits directly into the waste pipe.
danmac54
draining water system
:ROFLMAO:
Hi there!
thanks!
winterhill
37
Ambleside & Bolton
Hi Top
Thank you.
Ours did the same... but we managed to pick up a new tap from Todds at about £6.00
