Electrics (1 Viewer)
TheBig1
17,630
43,277
given your stated location, I expect it wont be as simple as just popping into your nearest dealership or calling out a mobile engineer. a good auto electrician may be able to help, but no guarantee
as PPJ said a post with an idea what the fault is would help
T
The Spongebobs
86
16
Oban, Argyll and Bute, UK
Hymer B584
I'm a newbie
Hi, I have a Hymer B584 and I have a problem with the 2x 12v interior spotlights. They keep blowing the fuse on the electrobloc 99. I have checked for a short circuit and cannot find one. I have now taken the lights off but the fuse keeps blowing. Have checked hob ignition and kitchen light, any suggestions please?
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
If you have taken the bulbs out but the fuse keeps blowing there has to be a short.. or it is something else blowing the fuse. With the bulbs out does it only blow when you turn the lights on.. if so the problem could be in the light switch.
Sep 10, 2013
1,187
18,697
Chelmsford Essex
Getting better
Fuses are in place to protect the wiring from damage or fire in the case of overload. If you have removed the lamp bulbs and still have an issue then something is shorting in the wiring from fuse to lamp, most likely in the switch. Have a look,your looking for a direct short to earth of the live, or between the live and neutral. Best of luck!
TheBig1
17,630
43,277
Pull the fuse and the bulbs then put a multimeter between the 2 connections for a bulb. first set to 20v dc and see if you have a reading. if not, switch to continuity and see if theres a dead short or 0 ohms. if its a short, which is probable, check the switch. then the easiest way to find the short is check each light etc attached to the circuit then follow the wiring and check for corrosion or damage
any basic auto electrician will do this first and charge £50+ per hour
T
The Spongebobs
86
16
Hymer B584
I'm a newbie
Thank you all for your replies. Lights all checked out and circuit tested, 10 amp fuse still blows as soon as the 12v system switched on. I have removed the lights and have new ones on order as a previous owner made a repair job on one of the switches, circuit still okay so it must be something else that the fuse protects from the elektroblok. This could be the ignition on the gas hob or the cooker hood light/fan. The last two seem okay but I am not sure how to test the ignition system on the cooker?
Rob e Lee
452
575
Surrey
Since 2011
It's best to disconnect switches to all lights - making sure wires are split apart and then see if fuse blows. There is potential for a switch to be making connection even when off.
Gellyneck
9,235
18,209
Scotland
More than toes wet now!
Boabs.
If you say there's free drink on offer half the blo*** Funsters will turn up tomorrow! It'll take the other half an extra day to get back over The Channel.:france:
They'll turn up but no fix anything mind you!:imoutahere:
Well not until the booze runs out and they achieve the unheard off condition of sobriety.
