Electrical calculations (2 Viewers)
Jan 16, 2014
790
1,916
Harleston, Harleston, Norfolk, UK
C Class, Autotrail Scout
Oct, 2013
Where V = Volts - Voltage
I = Amps - Currant
R = Ohms - Resistance
The illustration shows a simple way to remember the three formulae.
From the middle pyramid, we can deduce that I = V/R (i.e. that current flow increases with
increased voltage but reduces with increased resistance).
Where E = Volts - Voltage
I = Amps - Currant
W = Watts - Wattage
You can calculate the amount of power if you know two of the three electrical values – voltage, current and resistance.
See the formulae in the wheel (E, like V, is used to indicate voltage).
e.g. I = W/E or E/R
Aug 19, 2014
1,855
5,564
Cliftonville
A Class Burstner
Since 2014
The only formula I can ever remember is:
IVy watts is a powerful girl.....
Gellyneck
9,240
18,297
More than toes wet now!
SMA is no a bad formula!:xblush:
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
I have always used E rather than V for volts, all the formulae I remember and use have that notation.
In most daily usage you only need the basics to work out loadings, and in AC calculations Watts = VA X pf or (Volts X Amps) X power factor.
You shouldn't technically use Watts for AC loads unless their power factor is Unity or 1, ie: purely resistive loads.
Peter
2,338
10,140
except on this thread.. :xrofl::xrofl:;)
32,662
66,580
If you think of it as one of the following you won't go far wrong as a basis to then do other calculations:
  • the first two items, amps and volts, appear earlier in the alphabet than watts, so remember to multiply the first two to get the last ...
  • another way, always remembering it's a multiplication you're doing ... just scratch your head and think ... 'Watts the answer', ie A x V = W
:xThumb:
Jul 29, 2007
6,551
39,666
Ipswich
RV and PVC
30 years
My old maths teacher at college, said don't remember formulas, remember answers, like 100c is 212f, play around with 9/5 or 5/9 +or- 32 till it works out right. 250volts at 4amps is 1000watts.
Ian
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
So if I put my 2000w electric fire on for 24 hours at 8.7 pence per kwh
how much would it cost me?
32,662
66,580
32,662
66,580
a better duvet is a lot cheaper
A hoodie and bedsocks works well as does a nice hot dog on your feet! :D
32,662
66,580
nah can't stand stale bread and fried onions on my feet
Neither can I ... so I have one of these ... although when she lets out one of her farts it smells like hot dogs! :D
Nov 6, 2013
1,416
3,170
S. Ayrshire
The usual
Since the beginning
I'll stick with power calc and cable sizing Apps ta ;)
23,836
72,507
I have always used ( and taught ) is AVO
Avo is a well known make of meter and is always easy to remember
Same as above really but if you draw it like this:
It makes things real easy to remember
Amps Volts Ohms
Note where the cross is...
So you want to know what the voltage is ? A X O ( amps times ohms )
Want to know what amps are gonna be drawn ? V
/ O ( volts divide by ohms )
Or what he resistance is of a circuit ? V
/ A ( volts divide by amps )
32,662
66,580
