Electrical calculations
Discussion in 'Tech/Mech General' started by Mike B, Dec 20, 2014.
  1. Mike B
    Mike B Funster
    Jan 16, 2014
    794
    2,290
    Harleston, Norfolk
    Where V = Volts - Voltage
    I = Amps - Currant
    R = Ohms - Resistance
    The illustration shows a simple way to remember the three formulae.
    From the middle pyramid, we can deduce that I = V/R (i.e. that current flow increases with
    increased voltage but reduces with increased resistance).
    Where E = Volts - Voltage
    I = Amps - Currant
    W = Watts - Wattage
    You can calculate the amount of power if you know two of the three electrical values – voltage, current and resistance.
    See the formulae in the wheel (E, like V, is used to indicate voltage).
    e.g. I = W/E or E/R
    • Like it Like it x 5
  2. jdk62
    jdk62 Funster
    Aug 19, 2014
    617
    1,238
    The only formula I can ever remember is:
    IVy watts is a powerful girl.....
  3. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,789
    2,217
    Scotland
    SMA is no a bad formula!:xblush:
  4. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,604
    12,015
    E Yorks
    • Like it Like it x 1
  5. Peter A Forbes
    Peter A Forbes Funster
    Nov 23, 2014
    264
    182
    Rushden, Northants, UK
    I have always used E rather than V for volts, all the formulae I remember and use have that notation.
    In most daily usage you only need the basics to work out loadings, and in AC calculations Watts = VA X pf or (Volts X Amps) X power factor.
    You shouldn't technically use Watts for AC loads unless their power factor is Unity or 1, ie: purely resistive loads.
    Peter
  6. scotjimland
    Jul 25, 2007
    28,975
    25,674
    except on this thread.. :xrofl::xrofl:;)
  7. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    6,079
    11,389
    Glasgow
    Looks pretty confusing for me.
  8. Minxy Girl
    Aug 22, 2007
    10,604
    12,015
    E Yorks
    If you think of it as one of the following you won't go far wrong as a basis to then do other calculations:
    • the first two items, amps and volts, appear earlier in the alphabet than watts, so remember to multiply the first two to get the last ...
    • another way, always remembering it's a multiplication you're doing ... just scratch your head and think ... 'Watts the answer', ie A x V = W
    :xThumb:
  9. Geordies
    Geordies Funster
    May 29, 2013
    987
    2,280
    Tyneside
    Or the true electricians way, if the fuse blows, put in a bigger fuse.
    • Like it Like it x 4
  10. olley
    olley Funster
    Jul 29, 2007
    3,859
    2,446
    Ipswich
    My old maths teacher at college, said don't remember formulas, remember answers, like 100c is 212f, play around with 9/5 or 5/9 +or- 32 till it works out right. 250volts at 4amps is 1000watts.
    Ian
  11. laurieash
    laurieash Funster
    Jan 29, 2014
    659
    384
    HALIFAX
    So if I put my 2000w electric fire on for 24 hours at 8.7 pence per kwh
    how much would it cost me?
  12. scotjimland
    Jul 25, 2007
    28,975
    25,674
    2kw x 24hrs x 8.7p = 417.6p
  13. Minxy Girl
    Aug 22, 2007
    10,604
    12,015
    E Yorks
    .... unless it had a thermostat and cut out when it reached temperature ... :xgrin:
  14. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    a better duvet is a lot cheaper
  15. Minxy Girl
    Aug 22, 2007
    10,604
    12,015
    E Yorks
    A hoodie and bedsocks works well as does a nice hot dog on your feet! :D
  16. Wildman
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    nah can't stand stale bread and fried onions on my feet
  17. Minxy Girl
    Aug 22, 2007
    10,604
    12,015
    E Yorks
    Neither can I ... so I have one of these ... although when she lets out one of her farts it smells like hot dogs! :D
  18. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    1,022
    1,814
    Essex
    I'll stick with power calc and cable sizing Apps ta ;)
  19. laurieash
    laurieash Funster
    Jan 29, 2014
    659
    384
    HALIFAX
    So of I reduce to 1000w It would be half of that
  20. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,276
    3,080
    Kendal, Cumbria
    That's just cheating - she's gorgeous!
