Electric bikes (1 Viewer)
nelly
236
458
Sutton on Sea
Rapido 8090DF A Class
Since 2002
This might be a silly question but why is there not a system like my lights dynamo to recharge battery as you cycle along or would it just increase the cost to much
Neil
Bartyfixedit
330
566
Maidstone Kent
Self Build Ducato L4H3
Since 1987
Neil
If you pay a fortune then regenerative braking is available on very high end models. I think the jury is out as to whether there is any great benefit.
11,956
16,571
It would use more energy from the battery to operate the dynamo than the dynamo could replace. Otherwise we'd have free electricity everywhere.
Feb 21, 2016
4,920
29,648
Uk
Since 2017
Not a silly question. But I don't know the answer.
Do you normally recharge the batteries from the 12volt system whilst driving?
Is it possible to recharge them from solar panel,when stationary?
Not knicking the OP question,just curious!
nelly
nelly
236
458
Sutton on Sea
Since 2002
I have recharged them with an inverter and solar but only a couple of times it was good as well as when travelling with an inverter
Neil
Badknee
7,408
413,394
notloB
Vantage Neo
Living the dream.
Just a thought bu the dynamo on a bike is running two bulbs of very low wattage, I think it might need a lot more power to recharge a battery but I like the idea. F1 are using it right now but have thrown millions at it to try to make it work, Honda are failing miserably I'm sorry to say.
nelly
nelly
236
458
Sutton on Sea
Since 2002
I was thinking more of a top up to make it last longer as you go along not to totally recharge it i.e. start with a full charge
Neil
Silver-Fox
9,272
29,148
Cheltenham Spa
Rapido
im a not so newbie
The simple way of putting it is you don't get energy for nothing.
Or you get out what you put in sort of thing.
So the energy cancels itself out.
WSandME
368
453
Wigan-ish
Hymer B660 Bestline
SInce 2006
Only regenerative braking would make sense. Otherwise, your legs will be putting in power to the batteries as well as the wheels, so harder work, AND, the process of converting leg energy to battery energy is not efficient, so even more work required. As far as I'm aware, there are no "bolt-on" regenerative systems available (if there are, I would love to hear about them :) )
Mar 21, 2017
263
179
Devon, UK
Yep, you can't change the laws of physics.
I read somewhere that the regenerative braking on a ebike can extend your range by about 5%
I guess that means you only have to ride 100 miles downhill to gain 5 miles :D
Kevan
1,097
968
Kent and south west France
van conversion
30 years caravan/motorhome
Mine does tens of thousands on a full charge
But it uses a hell of a lot of petrol. :LOL:
No honest, really, look?
FULLY INTEGRATED Positioning the battery behind the seat tube is a tradition at Kalkhoff because it gives the bike a better centre of gravity, and thus offers a considerable advantage in terms of riding stability. What’s new, on the other hand, is the elegant look achieved by its perfect integration into the frame construction. This is achieved by our consistent implementation of the concept of component integration. And along the way, we have also optimised the handling of this long-distance power supply.
Impulse Evo battery uses incredible battery technology. With 50 high-performance cells and a capacity of 17 Ah, under ideal conditions power reserves give a range of up to 125 miles (200 km).
This new battery generation also offers durability, easy handling and rapid recharging. Cleverly, the dual-function charging socket also serves as a service interface through which software updates can be applied to your bike. Moving the battery lock to the top makes unlocking and removing the battery considerably easier.(y):)
263
179
Devon, UK
Bionx do conversion systems that have regen braking. http://ridebionx.com/products/ebike/ebike-systems/
Sep 3, 2012
7,559
26,089
Cheshire
C Class Elddis 175
8+ years
You could fit a sail and have a pedal free bike, or a solar panel as well to charge up the batteries:rofl::rofl::rofl:
Kevan
1,097
968
van conversion
125 miles? That must include a lot of pedal power!
Khalkoff's figures not mine, With 50 high-performance cells and a capacity of 17 Ah, under ideal conditions power reserves give a range of up to 125 miles (200 km).
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Just bought a Kalkhoff bike and when first used you have to fully charge the battery then keep riding the bike until the battery is fully discharged. This is to allow the charge indicator to calibrate apparently.
As we were going away in a few days I wanted to run the battery flat and recharge it before we left.
I rode uphill and down dale to try and discharge it but it just kept going, even with me using the highest power settings to use up the 'juice'.
Eventually it stopped driving the motor after 52 miles. It now shows a range of well over 100 miles on 'eco' setting, even though I have been on a couple of short rides.
Richard.
Mar 21, 2017
263
179
Devon, UK
My wife has a Kalkhoff that does 50-60 miles with mixed power usage. The big numbers the manufactures state is using eco only.
In reality the max range depends on level of fitness and the terrain.
