EHU France
Discussion in 'Motorhome Chat' started by snowdrops, Aug 12, 2014.
  1. snowdrops
    snowdrops Funster Life Member
    Sep 15, 2013
    685
    481
    Wales
    Well, after 6 months, our van is supposed to be ready in 10 days; right up to the wire as we leave for france in 2 weeks !!!!!! One thing we hadn't thought about was the hook up, done loads of uk camping in tents, caravans, campervans, however, never in France :unsure: Really silly question...... do we need an adaptor to hook up to the french aire/camping system ? ...... and why has someone at work mentioned a reverse current potential :eek: !!!!!!! ?
  2. jimiol
    jimiol Funster
    Dec 21, 2011
    172
    126
    Doonbeg Ireland
    Yes you do and I've heard that reverse polarity can be a problem in France you can can get a tester and and adapter off fleabay in time for your trip
  3. Geordies
    Geordies Funster
    May 29, 2013
    954
    2,184
    Tyneside
    Thought French sites used the blue "Rayroll" plug same as us ?
  4. iandsm
    iandsm Funster
    Jan 3, 2008
    1,625
    2,767
    Suffolk
    Usually you won't need an adaptor but on rare occasions you will need one for the French two pin type sockets, although the majority if sites have the same blue three pin sockets as we in the UK do. Most caravan/motorhome dealers sell adaptors and you can also buy them in France and you will find that some sites will lend you an adaptor if needed. (but better to take one with you) You plug you normal blue three pin plug into the adaptor and the goes into the two pin socket. As for reverse polarity, everything in your camper would work as normal if you ever experience it, which I haven't as far as I know. Site EHU will have an RCD and so should you motorhome, providing you are not taking electrical fittings apart whilst connected to EHU I wouldn't worry about it.
    • Like Like x 1
  5. mikebeaches
    mikebeaches Funster
    Feb 22, 2010
    1,093
    756
    Bristol
    • Like Like x 1
  6. Bertie Bassett
    Bertie Bassett Read Only Funster
    Jul 25, 2014
    2,743
    8,714
    I made a simple reverse polarity lead myself for those (rare) occasions when one has been needed.My missus wont let me into B&Q without adult supervision such is my diy ability, so if I can make up a lead that works anybody can!
    • Like Like x 1
  7. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,719
    8,809
    NW England
    The main EHU issue we've encountered in France is the distance from the pitches to the hook up post.
    I always carry two EHU cables in France, although with a solar panel we rarely (if ever) use either of them.
    • Like Like x 1
  8. Bertie Bassett
    Jul 25, 2014
    2,743
    8,714
    Seconded!
  9. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,603
    1,662
    Stretford
    Not quite true, The most important thing is the appliance live isn't fused (in the plug) with reversed polarity therefore it is protected by 16/20a mcb at the CU
    Also when something is switched off (light switch) as we tend to use SP ( single pole switches in the uk) in motorhomes (France use DP meaning both lines are disconnected) changing a bulb means the fitting is still live when you think it is switched off because you have in fact switched the neutral not the live with reverse polarity so to be absolutely sure switch of the mcb if you need to change bulbs or anything to do with the electrics
    • Like Like x 2
  10. peter125
    peter125 Read Only Funster
    Nov 26, 2012
    33
    9
    cardiff south wales
    dont get caught ,reverse polarity cost me my charger unit , got tester its more common than you think , also no neutaral just try in different socket and test again or use reversed polarity lead , buy kit of ebay or make your own , dont spoil your holiday
    • Like Like x 1
  11. Bertie Bassett
    Jul 25, 2014
    2,743
    8,714
    Useful info...many thanks, previously I must have been a hairs breadth from disaster a few times when fiddling with that, about which I knew nowt!
  12. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,807
    1,671
    Cornwall
    Greetings,
    And take one of those triangular meter box keys with you as well. (Or a 10mm socket)
    Handy for getting into the EHU box when you 'blow' the fuse. You won't have to bother the site management.
    • Like Like x 1
  13. MikeD
    MikeD Funster
    Dec 21, 2011
    2,126
    1,866
    London
    You definitely want to get the polarity correct.
    A plug tester on Ebay is only £3.45.
    Make or buy a lead for around £10.00.
    Its not worth getting it wrong for less than £15.00 (y)
    • Like Like x 1
  14. sb8263
    sb8263 Funster
    Apr 29, 2014
    651
    331
    leeds
    i got all mine from ebay.....
    • Like Like x 1
  15. snowdrops
    Sep 15, 2013
    685
    481
    Wales
    Thanx very much for that, as always, knowledgeable feedback :notworthy: I've been on ebay and bought the adaptor and the reverse polarity tester. Think we'll do without the polarity adaptor thing and just go without hook up if tests for that. Paying out so much as it's our first time abroad with new van eg maps, storage, outside chairs, european kit for van etc, thought we'd wait until next year for that. Thanx again :D
  16. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,078
    2,921
    Kendal, Cumbria
  17. Bertie Bassett
    Jul 25, 2014
    2,743
    8,714
    See Gorse Hill's #9, sums it up in a clear way that even I understood. (My capacity to fail at any form of diy is legend where I live)!
