ECOCAMEL SHOWER HEAD (3 Viewers)
Shrimp
May 27, 2015
3,988
33,499
Bedfordshire, UK
Hymer B584
Long time
How good is the Ecocamel?
How do I know which head to get? (Hymer enclosed shower cubicle.)
Where is the best place and price to get one?
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Had one fitted now for nearly two years and very pleased with it.
mariner
1,283
3,778
Isle of Dogs, but mostly Artola Spain.
Caravan
Since 2007. But no more.
If as this says it's output is 7 litres per minute, and my Boiler has a 14 litre capacity, that means 2 minutes of showering! Or am I missing something?
I use a trigger shower head which means 2 people can have a shower off one boiler full, quite comfortably.
:cooler:
sdc77
3,244
4,550
Weardale, Co Durham
:cooler:
Surely you're shower is a mixer... unless you have asbestos skin loads more than 2 minutes.
Also.. we don't leave our shower running constantly even with the ecocamel. There's normal three of us and no probs showering whatsoever
RowleyBirkinQC
2,348
227,180
Dazed & Confused
We are recent converts to the (low pressure) Ecocamel shower head in our van. From the 2 trips in which it has been used so far, its much better than the original shower head in our Auto Trail. Definitely seems to use less water without sacrificing effectiveness.
CWH
5,151
247,518
WildAx PVC
From November 2013
my Boiler has a 14 litre capacity ..... I use a trigger shower head which means 2 people can have a shower off one boiler full, quite comfortably.
Blimey! We also have a trigger shower head and I use less than one litre, and that's including my hair (which admittedly is quite short nowadays) and I still have friends :)
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
We bought a similar showerhead from Wilkos for a tenner we reckon it uses 30 percent less water then the original Hymer showerhead.
makems
3,440
27,723
Ingleby Barwick,,Teesside
Sadly had to give up
I fitted one to our Burstner after seeing them recommended here about two years ago. I can't say that it made any noticeable improvement to the showering experience and have no way of knowing if it actually uses less water as claimed.
32,673
66,645
I haven't got one and don't intent to pay the price asked for one but ... I assume it works by mixing air in with the water thus the flow of the water spray itself feels that it has been 'increased' and makes you believe you are getting just as good a shower as you did without it but with more water. At the same time I assume it restricts the water flow itself thus the claimed water saving ...
Well, that's my take on it!
32,673
66,645
Easily sorted - place a bucket in the shower and use the Eco head to fill it, making sure you time it using a stopwatch, then repeat without the shower head on and see how long it takes to fill the bucket ... then you will know if it is actually saving water or not.
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
we got one for our hymer and it lets us both shower one tank off water we bought it at the gt malvern show they seem to be at most off the big shows .as they have something in the head that stops them scaleing up which ps good as im concerned as we have hard water at home
Big Nick
260
290
Yorkshire
Low Profile Coachbuilt
Good product
Our MH has an 8 litre hot water tank but the hot water is RED hot so you probably use 75% cold to 25% mix
Anyway we both can have a quick but decent shower with minimal water usage
