Easylifter (1 Viewer)
Jun 22, 2014
558
748
Great Totham
PVC
Since 2015
I have an easylifter, hydraulic one. I intend to carry a scooter on it, so am looking for advice on the best way to secure it. I'm using ratchet straps but it there a best practice on how it's done?
MikeD
3,936
3,697
London
IH PVC
Since 2012
We have a easy lifter. Towed around 6000miles with a Vespa 300gts on it
I use a proper handle bar tie down strap and extra straps on both front and rear wheels
It can't move backwards or forwards and the handle bar strap stops it moving side to side
Not had a problem yet. (y)
zac
2,600
1,854
Basingstoke
Rapido A CLass 10000
since 2013
Bar straps is the way to go for sure, i usually do the side rail at the back each side as well (4 straps in total) and a chain around the front wheel to stop it moving backwards. I have some padding on the straps for the rails to stop it marking the bike.
Never had an issue yet :)
denisejoe
5,617
12,051
Warden isle of sheppy
Since 2004
I have eyes at front and back which easylifter do you have with or without wheels?
Joe
zac
2,600
1,854
Basingstoke
since 2013
Same here, i attach mine to the points where the rails attach. So i have 1 rail at the front and 1 at the back.
Not sure which version you have but if it is within the last year i would of thought yours would be the same.
zac
2,600
1,854
Basingstoke
since 2013
With out wheels
Ah sorry I have the hydratrail, i am assuming yours is this one Here
If so there are some eyelets near back and front tyres if the pics are anything to go by.
John and Jo
Jun 22, 2014
558
748
Great Totham
PVC
Since 2015
Yes saw that and good idea but mine hasn't got those. ..must be an older one. Mine came with the motorhome.
Jaws
23,836
72,486
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
You could just drill the base and bend some threaded rod to suit
Joe
Far better than threaded rod bent over is to use exhaust clamps u-bolts :)
Go to exhaust centre and but the clamps
Take clamps to local bolt stockist ( yellow pages ) and buy extra nuts
Drill the two holes per bracket
Discard the clamp part and use just the U bolt part of clamps
Fit U bolts using one nut above and one under the plate/bar/whatever
Sep 4, 2013
200
200
North Hants
Chatsworth CV40
Motorhome since 1997 Camping since 1990
I would also advise when fitting the U bolts to attach the ratchett straps so that they are permanently connected i.e. there is no way they could work loose and the strap come off. I also bought some seat belt shoulder protectors which fit round the strapping and protect the paintwork.
Colin
markh
247
243
C class
Lots
The most secure way is to have a ratchet strap to the frame above each shock absorber on the rear, and on the front to the frame or yoke by each front fork, then ratchet it down so the suspension is compressed, then apply the over seat clamp firmly, if you use the handle bar straps and do them up too tight, you'll bend the bars on a scoot, finally, check the nose weight of your towball and take into account the weight of the rack, before you choosing your scooter
John and Jo
Jun 22, 2014
558
748
Great Totham
PVC
Since 2015
cheers, I'll look at what I can do to achieve that. Done the weight bit and looks ok on paper & calcs, although I will be chucking it over a weighbridge again to check.
