Easy fit propane stainless steel hose (1 Viewer)
Branston1080
54
33
3 years
Evening::bigsmile:
If I want to change my gas hose to one of the gas low easy fit models, is it as simple as just unscrewing it from the regulator and swapping over or is it complicated?
Am I better off sticking with the need a spanner type hose?
17,644
43,457
just swap it out, couldn't be simpler. just turn off the cylinder/s first
Nov 30, 2009
6,548
149,160
Pickering
PVC the PUG
Its one of those jobs i did a few years ago now and swear by it, So easy to swap over bottles using the hand screw :thumb:
Seem to remember fitting an elbow to the top of the regulator to make the hose run neater.
Ralph.....
Branston1080
Branston1080
54
33
3 years
In theory
Sounds like a good plan. So am I right in thinking I just have to un screw the nut that attaches current hose to the regulator in my gas locker?
:Doh:
Because its gas I think I'm over complicating it. I'm afraid that years of observing that sharp in take of breath, followed by " it's complicated 'love' messy job" then out comes a spanner, two turns and that will be £££..
:ROFLMAO:
Jul 1, 2010
3,206
34,032
SW Northumberland
Hymer B 588 DL
Since September 2010
Its a very easy and straightforward, if your worried about leaks make up a soapy solution (water and fairy washing up liquid) and paint it onto the connector any leaks will be easily seen as bubbles just nip up nut a bit more till it stops.
Your gas locker is isolated and sealed from the habitation area and has drop holes/apertures to safely vent off any gas leakage.
GJH
29,450
38,827
None, now sold
2006 to 2022
Yes it is easy. I did it on our previous van. Just make sure you have a large enough spanner (19mm? can't really remember). I didn't but had an adjustable that did the trick. Don't forget to test for leaks as Stewart said.
