E&P Levelling System (2 Viewers)
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Since 2010 Caravan since 1995
Good morning,
I dont have one
But last week I was in a Dutch
Motorhome in Germany he had this, Fantastic!
Not only Levels if you need to drain tanks you can overide the auto function and tilt it.
It is a Dutch company might me cheaper to have a holiday in Holland and fit it there.
It is now a factory option on some German Motorhomes.
Not cheap
Mel
Cocoro
77
188
Europe
Since 2003
Goldschmidt Hubstutzen
Hi,
Yesterday I had the Goldschmidt Hydraulic Levellers fitted so too early to give a full evaluation but I would not have fitted them had I not thought they were fantastic. After two vans without them I knew it was a must have for this one! Had the front wheels 5cm off the ground yesterday trying different options! Bit surreal actually. But the stability when they are lowered is an additional factor. Having said that, the rams are fitted almost in line with the chassis (Iveco Daily 6ton chassis) so are not as wide spread as the wheels are. Therefore the stability is limited by the narrower stance. All the same, absolutely stable enough. I think with an Alko chassis the stance would be wider and therefore even more stable say in a hard wind.
Operation is so simple and quick. I think one downside could be that if there was ever a need to climb and exit a pavement you would have to be very careful that as you dropped down off the pavement the rams didn't hit it. Something I considered but decided was such a rare event not to worry about it. If your van is a low one then you can get the drop down rams from Goldschmidt with which this problem would be much less.
I'm a freaky 'leveller' guy so for me, the van has to be perfectly level every time. The hours I've spent levelling the van in the past with those yellow ramps doesn't bear thinking about. Great entertainment for others but not for my blood pressure. Now, the once dreaded moving to empty a tank or fill up with water or just nipping away in the van will be a breeze. Spending so long to get the van level meant I was always reluctant to move again for any reason!
They are expensive but if you won't miss the money, why not? And, you can have them taken off and put on your next van also. Nuff said.
Regards
Jeff
Jan 19, 2012
638
622
Leicester
Since 2012
Regards
Jeff
Not quite nuff said Jeff! Mrs ericonabike shares your distaste of slopes [me, I can sleep on a kiddy's slide if need be] but we have yet to decide if this is our 'forever van'. Knowing that you can transfer the system to another van puts a whole new light on it! Could you give us a clue as to initial cost of fitting and the ease/cost of transfer? Much obliged.
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
They look very good, though I must admit to never bothering much about levelling, as long as things don't slide off the table thats level enough for me.:Smile:
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Most American RV's have been fitted with leveling jacks, at manufacture, for years. :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
But maybe not for your fridge.
The weight would bother me. Every kilo counts in a MH.
sedge
Jul 7, 2009
5,504
13,115
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
We like level too LOL
As we sleep crosswise in the overcab, never want the head end to be down for starters. Awful that is.
Dead easy to tell when ours isn't, bathroom door is on the side and if you open the door and it moves either way then it just ain't flat. Can't bear it if it bangs back against the wardrobe door, always worried the doorknob will mark the woodgrain on the MDF.
We have a spirit level kept handy and as soon as we're parked, out it comes, got quite adept at judging how many steps we need to go up each side and whether front or rear by reading the bubbles LOL :roflmto:
scotjimland
2,327
10,087
A Woosh bang
me also .. 45 to 65kg weight of the standard leveling system ..
but on the plus side, the wallet would be lighter .. from £4,400 to £5,200, including fitting and VAT
canopus
6,139
10,257
rural Lincolnshire
Carado CV640 Pro
Since 2010
Yes we have the E&P sytem fitted on our Concorde. Excellent bit of kit. :thumb:
Good for emptying waste and you dont need a jack to get the wheels off.
Ideally you need a big payload in the first instance to offset the additional weight of the E&P System.
They now have agents in the UK by the way
R
rrusty
258
212
Scotland
None sold sept 2019
I got the E&P fitted in November and have not really tried them out yet, yes I agree about payload but I have got 1200kg
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
I got the E&P fitted in November and have not really tried them out yet, yes[HI] I agree about payload but I have got 1200kg[/HI]
now that i find hard to believe in a euro motorhome.
whats the base vehicle???
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
the link you show Jim is for a single axle version not a tag like the op has.
and with all the goodies he has fitted i very much doubt that it will come in under 4500kg without people in it.
Alde warm water heating
Engine heat exchanger with preheating unit
Air conditioning drivers cab
Airbag driver & passenger
Comfort-matic gearbox
3.0 litres
Cruise control
Alloys for heavy tandem axle
Front & back suspension incl automatic levelling for 3 axle
Exterior mirror with wide angle electrically adjusted and heated
Additional window near rear bed
Thermostat controlled fresh air fan above kitchen
Electrically driven front visors/ sun shutters
Awning 4.5 metres
Fly screen door
Leather upholstery
Lateral flap on garage drivers side.
Mirror on bathroom door
Storage box system in the double floor
Telescopic ladder
Carpets
Tie system in garage
Air conditioning on the roof
Satellite system
70 A combi charger with 1600 watt inverter
Outside shower
BBQ point on outside
Truma secumotion gas flow control incl Duomatic
Tec tower incl oven
Froli bed system
Elevating/folding roof Seitz above living area
Radio pre-installation sound system
Navigation system incl tuner, DVD, blue tooth and rear view camera
TV set behind seat pop up
Towing attachment
Thatcham cat 1 alarm system
Thatcham TQA tracking system
Spare wheel
Microwave
Submersible water fill pump
3rd gel battery for cabin 80 Ah
canopus
6,139
10,257
rural Lincolnshire
Carado CV640 Pro
Since 2010
The Concorde is on Merc 616 - 5990 kgs, with a towed mass of 6740kgs and axle loadings of front 2100kgs and rear 4360kgs
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
i hope you are not thinking that the towed mass counts as payload ken
scotjimland
2,327
10,087
A Woosh bang
ah.. my mistake.. I just looked at the model number..
R
rrusty
258
212
Scotland
None sold sept 2019
Rear 2 x 1500 Front 2000 = 5000
Last year in full touring mode with full tanks and 2 people on board = 4700
Cocoro
77
188
Europe
Since 2003
Hi. The cost for my 'Hubstutzen' from Goldschmidt was €4,700 plus VAT at 19% so £3,927 plus VAT. The price I was quoted in the UK from
Suffolk Leisure
Unit 32, Stonham Barns
Pettaugh Road
Stonham Aspal
Stowmarket
01449 710102 mob 07584 067500
who quoted £5495 inclusive of vat, fitting and delivery. I didn't use them only because I also wanted a gas tank fitted and Goldschmidt would do this at the same time. Also, I guess I did prefer a couple of the slight differences Goldschmidt offered. Less weight and both valves on each ram being on the top rather than the bottom of the body of the ram. I'm a ruminator so every little bit of safety helps don't you know! It did work out cheaper at Goldschmidt of course but factoring in the travel it would be about the same for a customer travelling in the UK. There was €621 net discount in my price also as it is the winter time I think. I do not have any idea what the cost to transfer the equipment to another van would be only that it is possible. They told me they do it for customers here and there. It wouldn't be too difficult to dismantle it all yourself really as it's only nuts and bolts, release hydraulic pipes, dismount the pump, unscrew the controller and there you have it so to speak. The labour cost for fitting I think was €1,100.
The cost for individual customers will vary as per the different type of van. Mainly the weight per jack and the height clearance under the van. I don't think E & P do retractable jacks/rams and these would be necessary for any low level/alko frame I think. I really like the idea of these but I needed pretty hefty ones so went for the 'Pro' category. Actually, they just stuck on what was necessary and wondered around like an idiot but I like to kid myself I was involved in the process!! I'm a big fan of using specialist for special things. This is all they do, that and air suspension, gas tanks, wheel spacers, springs, etc. Ok, not all they do but you get the picture. A team of guys just poured over the van and got both jobs done in less than two days. It would have taken less but the original tank was too big so we had a slight delay waiting for a smaller one to be delivered.
They weigh a bit, between 50 and 60 Kilo's but Goldschmidt have worked to keep the weight down now using alu where possible. Personally I don't care about the additional weight as long as I'm legal. I'd rather dump something else (did someone shout 'girlfriend'??) to have these jacks onboard as they mean stress free stops. Last night we stopped at a Tankstelle (motorway services), happened upon five parking spaces in their own little place but on a decent slope. We parked there, stopped, got out, pressed the button, stood back, marvelled at the technology and poured a beer. If my head is in anyway lower than my feet I feel it. I know, I too used to put the pillows at the other end and sleep there but then the shower wouldn't drain correctly and it went on and on.
It's a luxury item for sure but one gaining more popularity. We will I'm sure see more and more of them over the next years. I wanted to replace the Oyster Caro Digital to the more useful (for us Brits abroad) Oyster Digital 85 but I'll wait now due to the Jacks being fitted. A happy compromise.
canopus
6,139
10,257
rural Lincolnshire
Carado CV640 Pro
Since 2010
Our payload is 1655kg - so can afford the weight of the E&P system without compromising carrying everything else and the kitchen sink :ROFLMAO:
