Dunlop air suspension (2 Viewers)
BFM14
84
86
Leicester
We are going to fit Dunlop rear suspension to our Knaus Sky Ti and we have a question. What advantage is there to having the gauges and small compressor fitted as well? We have been advised that it is sufficient to have individual Schrader valve inflators in area of wheel arch; To be checked monthly using a pressure gauge. All opinions will be gratefully received
Nov 15, 2013
215
1,314
Rochester
5years Motorhome. 25yr tugger
I have fitted Dunlop air suspension to the rear of my motorhome with gauges and compressor. It comes in handy sometimes for levelling. Pumps up again quite quickly. Could be useful to be able to pump up higher before boarding a ferry to stop the rear grounding. Haven't tried this myself.
Sep 26, 2013
4,172
5,159
Market Rasen
Since 2003
As above the only benifit is if you have to keep changing the pressure to adjust the ride height. If not then no need to pay the extra.
Kensmith314
40
52
Shropshire
Knaus Sky Ti
Almost a year
Hi,
I can't answer your question but have exactly the same van as you and would love to know how much of a difference the new suspension makes.
When you have tried it for a while, perhaps you could post your findings?
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
I fitted this gauge in the garage of our last motorhome, and used a cheap tyre inflator from 12 volt socket.
John.
Badknee
7,408
413,046
notloB
Vantage Neo
Living the dream.
I have twin gauges behind cab seats each with it's own valve and a small compressor (6.99) under seat
Dec 11, 2011
839
2,102
Nr Hastings, East Sussex
AutoTrail Tracker RL
since 2010
Just have the schreader(sp?) valves on mine as I didn't think the additional cost of the gauges and compressor was worth it. Still happy with that decision a year later.
Apr 28, 2013
3,682
80,905
Alentejo,Portugal
Hymer A Class
Since the '80,s
Exactly as I had on my last van,no hassle just to undo valve cap fixed to rear of wheel arch for checking or adjusting pressure.
Found when pressure was right virtually no buffeting when passing HGV's and could bring the rear up to level after loading the scooter onto rack or with towing height.
Was really pleased when I found them on my S/hand van,dealer obviously didn't notice they were fitted as never mentioned it.
B
BFM14
84
86
Leicester
Thank you for all of your replies. Decision made, going to fit just the basic air suspension, will fit compressor etc later if proved that it is required.
JJ
Mágica
May 1, 2008
19,259
48,056
Burstner Privilege T
over 50 years
I did exactly the same as this... never bothered with the gauges ect.
(The air assist bags made a MASSIVE difference. Thoroughly recommended.)
JJ :cool:
Dec 11, 2011
839
2,102
since 2010
@BFM14 - one suggestion - run the air pipes to somewhere where you might be able to install the gauges/compressor if you later decide to. That might save rework and access might be easier than the wheel arch. I terminated mine in the gas locker as I have plenty of room there and access is easy. OK, so I wasn't thinking of adding a compressor later but at least I could add the gauges if I want to!
B
BFM14
84
86
Leicester
good idea for where to put the pipes!! Thanks
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I installed mine in the driverside footwell on my old Starspirit.
B
BFM14
84
86
Leicester
@Kensmith314 having now travelled through to the south of Germany I can now say that the addition of the Dunlop air suspension has been a great success. The ride is better and the cornering is totally different. It does not wallow as before and has become a much more stable machine.
Kensmith314
40
52
Shropshire
Knaus Sky Ti
Almost a year
Hi, and thank you very much for this information.
I'm going around Scotland for two weeks, beginning on Wednesday.
Perhaps when I come back I will look into having them fitted in time for my next outing in Europe.
H
Hagstrom
We have Dunlop Air Assistance on the rear axle of our Mercedes 518. It was fitted before we bought it but I haven't found that the lack of an instant method of increasing the pressure to have been inconvenient.
Once found, the optimum pressure doesn't need changing because our all up weight doesn't change much. (We are usually well loaded.) Once found, the optimum pressure has stabilised the van in buffeting & crosswind situations and at roundabouts.
The Assistance can help in increasing the max load the rear axle can take by as much as 200kgs. Our max design load was 2000kgs front, 3300kgs rear) but the converter had reduced this to 5000kgs overall. SVtech have certified recovery of the original design loads to 5300kgs and the Assistance enabled them to certify a further increase of 200kgs, to 5500kgs overall, as long as the individual axle maximums are not exceeded.
Norman
May 31, 2015
11,688
44,546
Ducato PVC
Getting Better
I have a Firestone system in my recent purchase, no gauges... What sort of pressure are people putting in theirs...? @Techno i noticed on your picture you had nearly 100psi, I think the previous owner said that about 35psi is in mine.. What factors are involved ? Or is it trial and error and just going with how feels when driving..?
Techno
Jul 28, 2010
15,475
20,756
May 2010
The 100psi is when first installing to help secure the pipe unions as per installation instructions
B
BFM14
84
86
Leicester
My Dunlop is set at 40 psi. Originally the installer said 45 psi but said that after a settling down period I was check that the back wasn't too high. It was so reduced to 40 psi and the vehicle is level.
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
How do you know if a Dunlop kit will fit a certain van ? if it has springs on the rear ?
SandraL
1,373
985
Somerset
Hymer b694sl
@Kool Kroozer
The Marcle Leisure site has lots of info about the Dunlop System, Other makes and dealers are available.....
Kool Kroozer
1,361
2,228
Always learning
Cant find my docs regarding chassis so dont know what it is i am driving around :LOL::LOL: all i know is that the cab is a Renault Master.. just took this pic from rear of the van - anyone know what it is ?
Neckender
3,221
5,921
Very similar to Fiat and Peugeot standard chassis, the air bags fit where your bump stops are fitted, after removing said bump stops.
John.
23,836
72,548
Similar to Paul.. I bought a nice set of mounted gauges, switches and buttons from VB, and then a compressor from the market that was about £7 from memory.
Our set up was best at about 32lbs pressure ( a tad over 2 bar ) so really did not need a massively expensive OTT pump !
Jul 29, 2013
9,071
18,566
Salisbury
Hymer B678DL A class
I read somewhere that Dunlop insisted on having a compressor installed with their kit to avoid problems with under inflation causing damage to the bellows,don't know if this is specific to any one type,I'm looking into having it fitted to the rear of our Exis 698i to help a bit when towing the car trailer.
