Dunlop air suspension
Discussion in 'Tech/Mech General' started by BFM14, Feb 4, 2016.
  1. BFM14
    BFM14 Funster
    Jan 24, 2015
    84
    94
    Leicester
    We are going to fit Dunlop rear suspension to our Knaus Sky Ti and we have a question. What advantage is there to having the gauges and small compressor fitted as well? We have been advised that it is sufficient to have individual Schrader valve inflators in area of wheel arch; To be checked monthly using a pressure gauge. All opinions will be gratefully received
  2. telsdog
    telsdog Funster
    Nov 15, 2013
    102
    428
    Rochester
    I have fitted Dunlop air suspension to the rear of my motorhome with gauges and compressor. It comes in handy sometimes for levelling. Pumps up again quite quickly. Could be useful to be able to pump up higher before boarding a ferry to stop the rear grounding. Haven't tried this myself.
    Terry
  3. Mikeco
    Mikeco Funster
    Sep 26, 2013
    732
    543
    Market Rasen
    As above the only benifit is if you have to keep changing the pressure to adjust the ride height. If not then no need to pay the extra.
  4. Kensmith314
    Kensmith314 Read Only Funster
    Mar 18, 2015
    40
    51
    Shropshire
    Hi,
    I can't answer your question but have exactly the same van as you and would love to know how much of a difference the new suspension makes.
    When you have tried it for a while, perhaps you could post your findings?
  5. Neckender
    Neckender Funster
    Oct 15, 2007
    1,271
    1,588
    Neckend or Benidorm
  6. Badknee
    Badknee Funster
    Aug 25, 2014
    3,782
    16,780
    notloB
    I have twin gauges behind cab seats each with it's own valve and a small compressor (6.99) under seat
  7. Bill_OR
    Bill_OR Funster
    Dec 11, 2011
    512
    689
    Nr Hastings, East Sussex
    Just have the schreader(sp?) valves on mine as I didn't think the additional cost of the gauges and compressor was worth it. Still happy with that decision a year later.
  8. Baldeagle7470
    Baldeagle7470 Funster
    Apr 28, 2013
    3,029
    1,495
    Charente,France and Alentejo,Portugal
    Exactly as I had on my last van,no hassle just to undo valve cap fixed to rear of wheel arch for checking or adjusting pressure.
    Found when pressure was right virtually no buffeting when passing HGV's and could bring the rear up to level after loading the scooter onto rack or with towing height.
    Was really pleased when I found them on my S/hand van,dealer obviously didn't notice they were fitted as never mentioned it.
    • Like it Like it x 1
  9. BFM14
    BFM14 Funster
    Jan 24, 2015
    84
    94
    Leicester
    Thank you for all of your replies. Decision made, going to fit just the basic air suspension, will fit compressor etc later if proved that it is required.
  10. JJ
    JJ Funster
    May 1, 2008
    14,871
    26,669
    I did exactly the same as this... never bothered with the gauges ect.
    (The air assist bags made a MASSIVE difference. Thoroughly recommended.)
    JJ :cool:
    • Like it Like it x 3
  11. Bill_OR
    Bill_OR Funster
    Dec 11, 2011
    512
    689
    @BFM14 - one suggestion - run the air pipes to somewhere where you might be able to install the gauges/compressor if you later decide to. That might save rework and access might be easier than the wheel arch. I terminated mine in the gas locker as I have plenty of room there and access is easy. OK, so I wasn't thinking of adding a compressor later but at least I could add the gauges if I want to!
  12. BFM14
    BFM14 Funster
    Jan 24, 2015
    84
    94
    Leicester
    good idea for where to put the pipes!! Thanks
  13. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,183
    15,157
    Leeds the one up North
    I installed mine in the driverside footwell on my old Starspirit.
    [​IMG]
  14. BFM14
    BFM14 Funster
    Jan 24, 2015
    84
    94
    Leicester
    @Kensmith314 having now travelled through to the south of Germany I can now say that the addition of the Dunlop air suspension has been a great success. The ride is better and the cornering is totally different. It does not wallow as before and has become a much more stable machine.
  15. Kensmith314
    Mar 18, 2015
    40
    51
    Shropshire
    Hi, and thank you very much for this information.
    I'm going around Scotland for two weeks, beginning on Wednesday.
    Perhaps when I come back I will look into having them fitted in time for my next outing in Europe.
  16. Hagstrom
    Hagstrom Funster
    Apr 13, 2011
    119
    99
    West Yorkshire
    We have Dunlop Air Assistance on the rear axle of our Mercedes 518. It was fitted before we bought it but I haven't found that the lack of an instant method of increasing the pressure to have been inconvenient.
    Once found, the optimum pressure doesn't need changing because our all up weight doesn't change much. (We are usually well loaded.) Once found, the optimum pressure has stabilised the van in buffeting & crosswind situations and at roundabouts.
    The Assistance can help in increasing the max load the rear axle can take by as much as 200kgs. Our max design load was 2000kgs front, 3300kgs rear) but the converter had reduced this to 5000kgs overall. SVtech have certified recovery of the original design loads to 5300kgs and the Assistance enabled them to certify a further increase of 200kgs, to 5500kgs overall, as long as the individual axle maximums are not exceeded.
    Norman
  17. Smith and Sharp
    Smith and Sharp Funster
    May 31, 2015
    1,581
    2,568
    Cornwall
    I have a Firestone system in my recent purchase, no gauges... What sort of pressure are people putting in theirs...? @Techno i noticed on your picture you had nearly 100psi, I think the previous owner said that about 35psi is in mine.. What factors are involved ? Or is it trial and error and just going with how feels when driving..?
  18. Techno
    Jul 28, 2010
    14,183
    15,157
    The 100psi is when first installing to help secure the pipe unions as per installation instructions
    • Informative Informative x 1
  19. BFM14
    BFM14 Funster
    Jan 24, 2015
    84
    94
    Leicester
    My Dunlop is set at 40 psi. Originally the installer said 45 psi but said that after a settling down period I was check that the back wasn't too high. It was so reduced to 40 psi and the vehicle is level.
    • Thanks Thanks x 1
  20. Neckender
    Neckender Funster
    Oct 15, 2007
    1,271
    1,588
    Neckend or Benidorm
    Ours as VB air assistance fitted and I run ours at 1.5 bar approx 22 psi.
    John.
