Ducato reversing judder (1 Viewer)
olewilliam
17
4
North Notts
Newbie (7 years towing)
I've trawled the site to find plenty on the reversing judder in Fiat Ducato's. However, most seem to say that it does not occur on the 3lt engine. Well it does on our's. We bought a 2010 Autotrail Tracker with a comformatic gear box. Very pleased with it too. Have done around 3500 miles. OK so far but... we avoid reversing on any slopes or wet grass if we can avoid it. The judder is frightening.
Have spoken to the local Fiat people and .... well if I can understand the conversation correctly I should practise better clutch control or learn to drive. OK for the latter but the hell I can find the clutch peddle:)
My question is what causes this judder, and I hope I'm stating the obvious in thinking this is very bad for the whole unit. And as I'm due to have a yearly service can I tell the garage anything that might solve the problem? One local garage has already informed me they will not service auto gear boxes because they have so much trouble with them.
Doesn't sound good. Any thoughts?
43,331
49,466
I wouldnt want them anywhere near it......they obviously dont know what a comfortmatic box is.
It is a standard manual box with robotised clutch and gearchange mechanisms.
The reverse judder on the 2.3 engines was allegedly an overgeared reverse ratio which was too high to be useful at low revs so the box started 'bouncing'
Fiats initial response was to rev the engine higher before letting out the clutch.....difficult with a robotised clutch.
From memory it involved engine and g/box mount replacement and possibly a new set of lower ratio reverse gears
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Mine is a 2008 3 litre comfortmatic with 42k miles and never juddered
Techno
Jul 28, 2010
15,475
20,756
May 2010
Just a thought but could the engine gearbox mountings be perished
IMHO that would be extremely unlikely given the age and such little mileage.
EDIT I see the OP does not say the mileage? only the mileage they have done
Minxy
32,656
66,565
E Yorks
Carthago Compactline
Have you actually checked the production year of your Fiat base? It could be one from one of the years when there 'were' problems with 'juddergate' being a 'swear word' to Fiat! Our van is a June 2012 registered Fiat but was actually built in 2011, this is not unusual, so you may find your base is older too, it has been known for some to be anywhere up to 3 years older than the registration date!!!! If yours is one of the older ones there may be a 'fix' which has not been done so worth finding out if you can.
As for how to manage it, have you tried putting on more revs? Although we have a standard manual gearbox which shouldn't be afflicted by judder, if hubby is a bit toooooo slow in his reversing it doesn't like it, putting just a little bit more power through does make a difference and any 'judder' disappears.
sean n maggie
672
327
leeds
autotrail
ours is the 3ltr Auto on 08 plate, up to now never had a problem it will reverse lovely almost just on tick over revs.....
Gauntlet
78
78
Lanarkshire
Don't own one yet
I'm a newbie
Same here 3lt model 08 plate no problems fantastic engine
Dec 28, 2011
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
2011 model, 3ltr with built in judder.
When I tried to get it sorted Fiats official answer was "more revs"
Funnily enough, I use tick over and clutch control and it only judders if I reverse to quickly.
Mar 17, 2013
389
389
Devon
Carado T339
Ours 2007 Fiat 3 litre - never had a judder problem!
Nov 30, 2009
6,547
148,996
Pickering
PVC the PUG
Ours is a 2006 , neither have we.
