Ducato Radio (2 Viewers)
pvw10
273
45
Gloucester
Coach built
since 2011 after tugging.
Hi all,
could you tell me please where your aerial is mounted, front left wing ?
Reason is my reception is poor yet a good quality radio is fitted, and no aerial visiible !!
I took the passenger side dash apart and behold the usual rubber aerial was found just lying on the car dash but under the plastic dash if you get what i mean, some lazy arsed installer from new i guess ?
I will if i have to drill the wing but any good alternatives ?
Oct 14, 2007
3,994
6,255
Rochester
Auto-Trail Mohawk
16 fun filled years
Believe it or not it's in the wing mirror and about as much use as a cat flap in a submarine.
I gave up and put one on the roof.
TheBig1
17,630
43,326
You are lucky, many have found that the aerial wire goes up towards the roof but was cut off when the converter removed the roof to fit the overcab.
I dont like drilling bodywork, so would recomend you fit an internal aerial that sticks to the inside of the windscreen.
Later model vans have the aerial built into the passenger door mirror
pvw10
pvw10
273
45
Gloucester
Coach built
Crikey didnt know that.
Are the windscreen ones ok then ?
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
radio aerial
If youre interested I have a windscreen aerial unused, pm me I bought it off e bay but have never fitted it:Doh:
TheBig1
17,630
43,326
the better quality ones with an amplifier work, the ones for about £5 and just stickybacked plastic not so good
pvw10
pvw10
273
45
Gloucester
Coach built
Thanks i will check it out as drilling holes in wings is a last resort for sure.
brynric
731
1,555
Worcestershire
Pilote G600
Mine is stuck to the windscreen. It seems fine but then I don't listen to a lot of radio.
bobh
37
5
Powys
Low profile
Several Years
Hi all,
Had rubish reception on my 2010 ducato so dealer fitted a n/s wing aerial
and said they do a lot of them reception now better but not perfect:Eeek:
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
WE had a bendy rubber aerial fitted on the left hand front wing of our Ducato, and the radio works fine.
Cossieg
221
98
Yate for the summer!
None now
Attached is the Autotrail wiring diagram. You can see that the aerial is supposed to be in the NS mirror. Mine didn't work so I ran a cable from the status aerial to the head unit & that works well.
lesr48
98
85
Ilkeston, Derbyshire
Rimor Katamarano
Since 2014
Mine is a useless piece of rubbery plastic sticking out of the nearside wing. Reception is crap and I am thinking of replacing it with one fitted into the lockers over the windscreen.
GJH
29,450
38,827
None, now sold
2006 to 2022
Different type of van and aerial but it might be the same external screw connection problem as we had. Fixed it using a dab of petroleum jelly as described Broken Link Removed. It might be worth a go before spending more money.
Jan 28, 2008
10,117
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
the small panel above the head lights is plastic easy to drill and esay to replace if iut goes wrong thing you have to line with foil to get a ground plane or so im told
lesr48
98
85
Rimor Katamarano
Since 2014
Thanks for that GJH, I'll give it a go.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
An alternative to drilling 'oles: mount the aerial on the edge of your solar panel & bring the cable in through the same hole. only works if you have a solar panel.:D
A more sensible tip: before fitting a replacement buy a cheap car aerial & a coax extension then in a weak signal area try it in various positions on the van until you get the best results. Which will be on the edge of your solar panel.
RS_rob
1,010
669
Turnford
over a Year Yay................
No I only get reception when parked, luckily I do have a hole in the wing & working on fixing this issue for good.
