where is the radio aerial on a ci carioca 694 (1 Viewer)
ukbill
5,501
5,274
Pinoso
4 berth low profile
starting on saturday 10/3/2012
i have tried to trace the ariel for the cab radio and got as far as the cooker after tracing it from the dash to behind the water pump then the waster tank then it goes behind the sink and the cooker and i gave up does anyone know where this ariel goes to i have nothing poking out of the roof or anywhere i can see so now im at a ;loss the radio in the van is extremely limited to its reception in so much as i can only get any stations when near or in a town the radio is a pioneer so should be good and is around 6mths old any ideas before i try to install another Ariel please
Feb 16, 2013
19,735
52,033
uttoxeter
ambulance conversion
50 years
Don't know about your model but believe it or not the airial in most of the fiat based vans is in the PASSANGER MIRROR!!!, crazy and rubbish
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
thx but mine cant be there unless the bloody cable goes all the way around the van i reckon i will be better to stick another ariel on the van
Feb 16, 2013
19,735
52,033
uttoxeter
50 years
Stranger things have happened in these vans, can't reverse them drain all over the engine, why do we put up with them(n)
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
what else would we have to moan about :)
car shop tomorrow for a Ariel i reckon :D
43,331
49,463
Could be in the mirror but bear in mind, the base vehicle is primarily commercial and it was possibly on the cab roof.
Obviously it can't be there AND the overlap bodywork so converters simply remove the aerial from the roof and don't bother replacing it.
TerryL
6,187
8,190
North East
Low Profile
I'd guess that the wires you're tracing to the back could be for speakers or the tv point (even if you haven't got any). Standard place for the Sevel X250 is the nearside mirror. But if it ain't there then you won't be the first to fit an extra aerial.
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
its defo the ariel cable not speaker or anything else i have traced it all the way like i said i stopped at the cooker absolute madness just to run it that far :)
Feb 16, 2013
19,735
52,033
uttoxeter
50 years
I have found with mine if I get a piece of coax and poke it in the airial hole in the back of the radio and just chuck the other end on the floor of the van reception is 10 times better, just give up on it now and just use it for cds
Rayb182
Nov 13, 2009
1,523
2,223
Great Bentley
Sundance 590 PR
Since 1999
I've got an ariel if you want one for the mirror and we are only up the road, was going to sling it but thought it might come in handy.
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
thx but i reckon i will get 1 attached to the side i am then feed the cable through the cavity :)
Badknee
7,408
412,819
notloB
Vantage Neo
Living the dream.
Ours seems to be a black box glued to the inside of the windscreen top left n/s and it's crap.
gozomike
Funster Life Member
1,001
863
Warwickshire - sometimes - but not often
Wildax Constellation
Since August 2008
If it's a coach build why bother with an outside aerial, a length of wire running around the inside of the roof will work unless there is a metalic insulation in the body. If there is try connecting to that.
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
ok i will try that
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
i found the original ariel after pappajohn said about a roof 1 i decided to check and there was the fitting for a roof ariel but of course the ariel itself had been removed the cable was just tucked down the back of the console i have now attached the ariel with some wire to the metal part of the roof and its a much better signal where the other 1 goes i really dont know and im not taking most of the van apart to find the thing i will buy a small roof ariel and refit it where the original is why they took this 1 away is beyond me it must have been 1 hell of a job to run the new 1
musson
487
165
grantham
low profile
since Jan 2014
Hi i found two ariel connections behind the radio tried both neither work (Fiat Ducato) I looked at fitting one
in the wing but gave up,ended up fitting a flexi rubber ariel laying at the bottom of the window inside
you would not know its there, wire comes out just under clipboard ,it works better but not spot on with all channels.(smooth/radio 2 ok)
Bailey58
8,817
29,579
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
The radio on the Boxer is useless too but at least there is an external aerial on the near side pillar. I need to investigate whether it actually connects to the radio.
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
anyone tried 1 of these
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
kk thx
appydaze
728
1,847
southend on sea essex
Merc high top
20 years
I was told that the black banding inside top of windscreen that runs width of the windscreen was actually the ariel.
JimJams
249
377
East Sussex / Kent
RV, A Class
since 2003
Unfortunately you are fighting a losing battle when it comes down to FM reception :(..
This is also only going to get worse as times goes on, as the reception from the transmitters are being gradually faded out to be replaced for DAB+..
We have tried many, many, many aerials over the years, from windscreen, to mirror, to external mounted and the best signal strength came from the mirror mounted aerials..
Mostly you will find that you receive a signal whilst stationary with the engine off, but whilst on the move reception very quickly drops off... Very frustrating !!! :banghead:
Pioneer even install a devise into their headunits that is meant to help towards the problem with reception dropping off when the engine is running.. And this dosent really work!!
Before you spend allot of money on external mounted aerials then yes get a new iPod / CD selection or invest into the future and change your system and install the latest DAB radio.. (y)
Feb 16, 2013
19,735
52,033
uttoxeter
50 years
Do dab car radios work in France, only ask as we have a dab radio in the house , works perfect, took it to france with us couldn't get a peep out of it anywhere
JimJams
249
377
East Sussex / Kent
RV, A Class
since 2003
You will probably find that your radio will only allow you to pick up Band 3. Band 3 is what most DAB radios that are sold in the UK only use.
DAB reception over France has now 62% coverage.. unlike here in the UK, DAB is ahead of schedule!!
To pick up DAB abroad in other countries you need a radio that can also use L band to broadcast as well as our band 3,
Please remember you won't be able to pick up UK stations there.
JimJams
249
377
East Sussex / Kent
RV, A Class
since 2003
Also we only sell Pioneer systems.. This is because they are European wide products..
This means it will be able to pick up all the standard bands through out Europe.
Also they use DAB+ which is the highest Euro standard..
And also I wouldn't fit anything less in my own motorhome!!! ;)
Bailey58
8,817
29,579
Norfolk and Toftir.
Sold
So why do the radios in the 2 cars still perform perfectly wherever we are even if it means clicking up to the next pre-tuned signal on Radio 3/4/Classic, oh alright then, Radio 1, whereas that on the motorhome started useless and is still useless?
And another thing, what's happened to eddievanbitz, has there been a takeover? :cautious:
Feb 16, 2013
19,735
52,033
uttoxeter
50 years
What sort of airial do you need for dab, if it's useing the van one , is it still going to be crap
JimJams
249
377
East Sussex / Kent
RV, A Class
since 2003
Ha Ha,,, The mighty Eddievanbitz will always be here to give his opinion!!!
the biggest problem with FM aerials ( I'm assume that's what you are asking about) on a motorhome is that a factory mounted aerial which is attached to factory metal body has been removed when the motorhome build manufacturer comes along and adds there bit (fiberglass) to the back.. and to be honest there isn't a decent aerial which is reliable available on the market as a aftermarket product.. It doesn't matter what grounding plate or booster you add they just don't work!!
Customers with panel van conversations with a factory stereo set up, generally don't have the problems that couchbuilt motorhomes have..
We had a van in one day manufactured by Autotrail and the customer had 12 aerials over a short period of time installed by Autotrail to try and get over his FM reception problem.. nothing solved his problem which is why he decided to invest in a DAB radio..
JimJams
249
377
East Sussex / Kent
RV, A Class
since 2003
For DAB+ you need a new aerial..
There are many on the market. We use the standard recommended Pioneer windscreen mounted aerial. that retails around £25.00. We have had back really good feedback..
On my van this is the one I have installed and when I'm in Taunton working the digital strength there is superb but where I live Sussex and also areas where i travel round and work like in kent, you will find there are a few dull spots..
As there are certain areas at the moment that are not as good as others, you can buy external mounted.. there are loads to choose from and they start around £100.00 for a good one. Allot of the websites that sell these aerials also give you a star rating on how good the performance of the aerial will be on reception quality..
