Ducato Leisure battery wiring
Discussion in 'Self-Build Motorhomes' started by Pouschkin, Feb 17, 2016.
  1. Pouschkin
    Pouschkin Read Only Funster
    Feb 17, 2016
    5
    Barcelona
    Good day all, I just joined so totally newbee. I´m undertaking my first van conversion, it´s a facelifted mkII Ducato L2H2 and already running into a brainbreaker.
    I´m planning on installing a leisure battery and am planning to run a 25mm2 cable from engine battery to leisure battery. The battery will be located above the rear left wheel. Now, what´s the best way to run the B2B cable? Anyone got experience wiring a Mk2 Ducato? Can I go over the passenger door (through A-style) or under it, or maybe even under the van? I´m planning an insulated floor, so there is space under the floor as well.
    I´m trying to avoid having to take apart the entire dashboard to define a route, also, I´m unable to see where the rear lights cable harness is running. Also, since I´m living in Barcelona, my sliding door is on the right side and does not create any problems.
    Any (good) advice is welcome! Thanks in advance.
  2. lorger
    lorger Funster
    Jul 11, 2008
    6,401
    7,850
    Dumfries
    I don't have the answer to your question just thought I'd say hi, I do know that most fiat ducato conversions seem to have the battery under the passenger or drivers seat not sure if this would make things easier or not.
  3. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,757
    3,395
    Cumbria
    Hi, I'm not familiar with the Ducato, but if you check out www.deepredmotorhome.com you might find an answer there, lots of good fiat pvc conversion info there (y)
  4. Pouschkin
    Feb 17, 2016
    5
    Barcelona
    Hey guys, thanks for the quick replies. Deepred is one of my inspirations indeed, but exactly on that topic, it´s not compatible. It´s a newer ducato with the battery in the cabin instead of in the engine bay.
    Good point about the battery being under the seats, I didn´t even consider it. I placed it close to the peripheral equipment (UPS & aux fusebox).
    • Like it Like it x 1
  5. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,280
    3,728
    walthamstow east london
    if you lift the mats in the front you will find there are conduits built in which will get you to the post behind the door from there i went along the side of the van in flexi conduit my batteries are on drivers side
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,923
    YO11 2BD
    Not a good idea to link both hab and cab batteries permenantly.
    Not only will you charge both with the engine running but will also drain both with the engine off if no hookup available.
    A B2B charge module would be a far better option, albeit much more expensive, as its only active when the engine is running.
    This link is to the 50amp version but there is a 20amp model too.
    http://sterling-power.com/collectio...chargers/products/battery-to-battery-chargers
  7. Pouschkin
    Feb 17, 2016
    5
    Barcelona
    Thanks, I´ll have a look next time. That would be a nice and simple solution.
    Thanks for the feedback. I wasn´t planning on doing this. I was thinking on integrating a 100A split relay. I´ve seen those SP B2B chargers before but I really don´t want to break the bank over those, I´m already pushing it with a UPS.
    What do you guys think of this:
  8. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,635
    10,747
    Lorca,Murcia,Spain
    Hi & welcome
  9. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,280
    3,728
    what do you need an invertor for ?its best to use a split charge relay and run everything you possibly can on 12v when not on hook up
    have you been to the self build motor caravan club web site sbmcc.co.uk you will get lots of wiring diagrams on there as well as a mine of infomation
  10. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,280
    3,728
    my batteries are at the back but with hind site i would go for puttting them under the seats saves a lot of wiring
  11. Pouschkin
    Feb 17, 2016
    5
    Barcelona
    Thanks Gus.
    I´ll have a split charge relay for sure, but I want to have both 220 and 12 volts all the time. I´ll have a look around on SBMCC, should I specifically look on the forum?
  12. Pouschkin
    Feb 17, 2016
    5
    Barcelona
    More and more playing with the idea not to invert to 220. It would save me the UPS and would just need a charger.
    Also thinking about a high-load step down to build a 5v infra and place several USB points (everything seems to connect and charge through USB these days).
