Ducato engine noise (2 Viewers)
Road Burner
70
9
NORFOLK
Coach Built low
SINCE 2008
I have a fairly new 2010 Fiat Ducato 2.3 ( Bessacar E560) When the engine is idling , for example stopping at traffic lights we occasionally hear a soft hissing and popping sound from the engine which is audable from the top of the dash on the nearside. Has anyone else experienced this and should I be worried?
Aug 27, 2009
19,788
23,077
Hertfordshire
40 years
Check that you didn't leave the chip pan on the heat.:Smile:
23,836
72,558
It is almost certainly the rebreather circuit, but I would suggest you get it checked out JUST in case it is a leak on the brake servo ( for instance )
bernardfeay
613
1,191
Bolton
hymer exsis
10 years
steering fluid leak
Of course it is hard to describe an engine sound so the sound we heard might not be the same. But, we had a steering fluid leak that made a similar noise. If you put newspaper under the engine when you park up you might spot drops that give a clue to where the leak is.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Check the fuel filter is tight, and the fuel rail is ok. Earlier models had a recall on the fuel rail - but should be OK in these. The fuel filter is located nearside at the top of the bay - so may be where the sound is coming from.
