Ducato 16in wheels - what valves (2 Viewers)
Cossieg
221
98
Yate for the summer!
None now
Hi all. I've searched far and wide to find definitive advice on where to buy the correct metal valves for my Autotrail Comanche wheels. I've bought a secondhand wheel and want to get a new valve to put in it before I take it to have a new tyre put on. Does anyone have the right dimensions etc or better still a place to buy them? I note that tyresavers seem to have some on their website at £30 for 4 but this seems v expensive. Cheers
Bartyfixedit
330
566
Maidstone Kent
Self Build Ducato L4H3
Since 1987
Any good? They do smaller quantities.
Sep 27, 2007
837
289
Shropshire based
Globecar
started in 2001
I would have thought the tyre fitter would supply one, in with the fitting, just ensure he knows what its going to be used on and specify high pressure valve.
Cossieg
Cossieg
221
98
None now
Thanks very much for the prompt replies! Last time I went to the local dealers none had metal valves in stock so I want to get some myself & remove the issue! Not sure about the EBay listing you link to Bartyfixedit they don't seem to be all metal so I'm not sure. I did look at the listing previously. Keep up the good work!
11,956
16,570
They don't have to be all-metal (with a compression nut). They can be conventional fitting with a reinforced base. Three types are pictured here - first two and fourth photos):
Apr 29, 2009
1,204
741
West Sussex
Burstner Nexxo T740
I am also looking for one - I have just bought a Fiat Alloy but none of the local tyre places have the valve for it. I will either have them take it off the old one as its the rim thats leaking or maybe we can go split a set? (Although I've just seen where you are so maybe not practical)
Cossieg
Cossieg
221
98
None now
Thanks everyone.
I think either Schrader or Alligator are the right valves for me given the pressures etc. I've found a couple of dealers, Auto4 and PTA Shrewsbury. I haven't ordered any yet though!
Apr 29, 2009
1,204
741
West Sussex
Burstner Nexxo T740
That looks a good bet - we had a result - our local Tyre place - (Hi Q) had a high pressure metal valve in stock so fitted it all now good.
