Ducato 130 Multijet - Good Choice? (1 Viewer)
RACER101
5
Nr. Lockerbie, Scotland
Deciding What To Buy
Just Starting
Just starting to gather advice & information to help us decide on our first MH (aiming to be on the road in early Spring 2012).
Our basic requirements are a 2 berth coachbuilt and it looks as though our budget will be enough to get us a low mileage model less than 3 years old.
My first question is what engine & chassis combination to go for and the related issues of performance & fuel consumption are at the forefront of my mind.
Having driven a lot of miles in an lovely old Merc Hymer (belonging to a friend) I know only too well how tiresome / stressful it can be to drive an asthmatic, underpowered vehicle that struggles to keep pace with traffic.
The 130 Multijet TDI seems to be commonly available and the figures for power, torque & fuel consumption look pretty impressive...............but is it actually as good as it seems in real world everyday usage? Does it have any known weaknesses that I should be aware of? I understand these engines are sometimes 'chipped' for more power & torque. Are the claims genuine or just 'snake oil', how do insurance companies react and are there any real world benefits to be had from doing it?
What other engine/chassis combinations are worth considering and, perhaps more importantly, which ones should be avoided at all costs? Bear in mind that I will probably sometimes be towing a lightweight trailer & car (less than 750Kg).
Any advice and personal experiences will be very gratefully received :Smile:
Thanks in advance,
John
Dec 23, 2007
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
I had one:Angry: first check you garage is on a bus route and has comfortable customer lounge!!
meanders
Funster - Life Member
2,606
8,441
Ipswich, Suffolk
C class
Since 2004
Ducato 130 multijet
We have a motorhome based on the Ducato, there were problems with reverse judder on these but since ours was fixed we have had no further problems. We find for our Bessacarr the engine is certainly plenty powerful enough and we get roughly 25 miles to the gallon. Others have had problems but we have always had good service from Fiat, and the engine has not let us down.
Rayb182
Nov 13, 2009
1,523
2,223
Great Bentley
Sundance 590 PR
Since 1999
We have the Fiat 160, the extra power so much better, dont have to keep your foot on the pedal, and no cam belt
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Earlier models as stated above seemed a bit of a lottery as to reversing judder, don't know if completely cured, but seems to have been better of late. If buying second-hand be sure modifications have been done, and test drive reversing up a steep slope, and if possible reversing up a grass slope.
Personally if only a 2 birth would seriously consider a low profile (no luton) as they will give better MPG not drastic but every little helps, would go for a German motorhome, seem to be better build quality.
Other base units worth a look Ford or Merc .
R
RACER101
5
Just Starting
Wow, sounds like you had a really rough time with yours :Sad:. Would you care to elaborate please? Might give me some pointers about what to look out for when the time comes for me to do some viewings.
Thanks,
John
R
RACER101
5
Just Starting
Does the bigger engine capacity damage the fuel consumption much (compared to the smaller/less powerful variants) or do you find that it works out much the same because you don't have to thrash it to death in order to keep up momentum?
Thanks,
John
motorhomer
680
418
South Shropshire
Van Conversion
since 2005 (but 30 years caravanning)
I have had 2 160's (actually peugeot but the same van) and now have a 130 ducato.
The 130 is not as powerful as the 160 but is perfectly adequate and in my experience slightly more economical.
Neither 160 was trouble free, I had engine trouble with both, but so far have had no trouble at all with the 130.
The main reason I opted for the 130 - apart from price - was to save 50kg weight.
There were reports of reversing judder but I never experienced this, and my 130 is fine.
The ducato base is a delight to drive. Mine has the alco rear chassis which gives independant rear suspension, and it works very well.
But I always say choose the van you want to live in, any of the modern base vehicles should be OK.
pablomc
772
237
Durham
Since 2009
I have the 130 (bought 2010) and no problems encountered. I have also opted for a remap (no issue with insurance) which has made it even more drivable. There are a few threads on remapping if you do a search.
DuxDeluxe
14,658
72,782
Planet Zog
A woosh bang van
since 2008
I've got the 160 and it is an absolute delight to drive. I would have been happy with the 130 as well. There are good and bad things about all base vehicles and you hear more bad stories about Fiats simply because there are many more of them around. I think that the reported problems with the clutch judder have nearly all been resolved with modifications and although there was no "fix" on the 160 (Fiat said it wasn't a problem) I understand that the clutch material was differently specced from 2009 onwards.
Any of the base vehicles are good - my own preference was for the Fiat/Al-Ko combination, but had the right Mercedes come along then that would have been the choice - at quite a substantial price premium, though
348
315
anglesey
Autotrail Delaware
since 1999
i agree with motorhomer go for what suits you i worked on owned bought and sold lived and breathed transits since they first came out in the mid sixties so when we bought our first motor home it had to be a transit nothing wrong with it 2.4td went like a train but a bit thirsty with a big overcab body
after a couple of years decided on a change found autotrail cherokee fitted all our requirements but only available on fiat chassis, however after much deliberation decided on the 2.3 to save the weight
5 months later [a month early by the way] motor home arrives but on heavier chassis 4250kg insteed of 4050kg so you just cant win however i im very impressed with it drives really well not so much power as the transit as yet but only done 1000mls or so but the gearing makes up for it although i still think that reverse is still to high ratio drive as four speed around town 2000rpm in sixth gives a very comfortable 60 miles an hour on the motorway and around 25mpg
as said before not a lot to choose all vehicles have knockers and praisers
paulus the woodgnome
640
298
Nottingham
c class
4 years 2 months
went to venice in mine last year over the swiss mountains upto andermatt and down the other side and over the italian dolomites with no problems
just come back from salou and cambrills in spain over the midi pyrenees and back through andorra we dont use the tunnels we always go over the top for the views
lunch at the top near the french border was a treat
no probs with the climb or the milage and this is a 7.35m van
:thumb:
beachcaster
3,044
3,161
east sussex
a few years
I too have the 160 in an automatic.
No judders at all....its a pleasure to drive.......and the auto box is smooth and a real treat to drive. About 25 to the gallon.
barry
R
RACER101
5
Just Starting
Thanks to everyone that has taken the time & trouble to reply :thumb:
The consensus seems to be that the Ducato 130 Multijet is generally regarded as a pretty good choice but, like most mechanical things, it isn't perfect.
The other very helpful message coming across is that most (all?) of the modern breed of engine/chassis combinations work well and that I should be open minded about other manufacturers.
Next on my list is the much more complex question of layout...........the permutations seem endless to me!
Thanks again for all the helpful contributions.
John
845
1,251
Nuneaton. Only when I have to.
Hymer Exsis t564
Since Sept 2010
You should really consider a MH based on the Transit 2.2 TDCi Duratorq engine.
Preferably the 140PS version (available from either 2006 or 2008 I think). Very driveable, pulls and cruises well up and down dale. Perhaps more van like than the Fiat but very capable and no nonsense.
keithfal
33
Worcester area
C class Ducato LP
36 months
Choosing a base vehicle
John
Sorry I'm a bit late jumping in with my comments but we have just returned from a 4 week tour of Iceland where there was a considerable amount of driving on unsealed/gravel roads of very variable surface quality. Of the 24 units on the tour the vast majority were based on Fiat Ducatos, including ours. The only van to give any trouble over the 3000 mile trip was a Hymer on a FORD base. But since this was a broken battery we can ignore that. So I reckon this proves that Ducatos are comparable with any other base vehicle.
Put this with the fact that my son-in-law who drives a Renault Master in his work as an international courier, was very impressed by the performance of the Fiat when they took the van to France for a 2000 mile trip esarlier this year and reckoned it outperformed the renualt easily.
Ours is a bessacarr E520 chosen for its practical 2 berth rear lounge but also for the performance and economy of its 130Multijet engine. We get up to 29 mpg without trying and I will be trying to get 30 in France this autumn given the price of fuel.
Incidentally diesel in Iceland is cheaper than in the UK in a high tax country where everything is imported - whats that about?
Good luck with the choice (oh I've just remembered, the reversing judder did occur on my previous Fiat but this new one it doesnt, and Unless you expect to have to reverse for miles uphill, I'm not sure that it matters that much anyway).
Keith
tommytli
May 26, 2009
434
26
lancashire
coach built
since july 07
ive just changed my motorhome and the new one is a 2011 fiat ducato 130 multi jet the old one 2008 transit 140bhp, ive only drove the fiat home so cant give a proper review but compared to the transit its as flat as a fart! im going to italy this week in it so i will report back on how it shapes up loaded and over a few thousand miles, but 1st impressions a remap is on the cards.
DESCO
2,646
266
London
low profile
As an addition to my earlier post I have just done the analysis of the figures from our first trip to Scotland in our new Ford Transit based Hobby, it is a front wheel drive 2.2 140 with a 6 speed gear box.
For a new motor it averaged 31.5miles over 2.500 miles over all types of road, which I think can only improve as it gets more miles under its belt. I must say I did think I would chip but performance is better than expected over previous van so will leave alone.
Previous Transit was 2.2 130 with 5 speed gear box and although I was happy with this I think the later van is a definite improvement.
2,747
9,575
Chester
Auto-trail
Well that`s our 13th year & still loving it.
ducato
We have a Fiat 3 litre 160 multijet in our Autotrail Arapaho, the engine going forward is a delight, it has been re-mapped and get an average of 27 mpg at 60 mph on the motorway, though that figure will drop down to 21mpg into a head wind.
The engine definitely doesn`t like going uphill in reverse, the ratio is just too high, as previously stated there is a fix for the smaller 2.3 engine but Fiat have abandoned the 3 litre engine owners.
The problem first arose with the introduction of the 6 speed gearbox, engines with the old 5 speed don`t have this problem.
Fiat have taken a long time to get to grips with this, it was thought that if you bought one after October 2010 you would be safe, however I spoke to someone last week and he had bought one in June 2011 and his has the problem, (you never know how long it has been sat in a compound before you buy a guide might be checking the date on the tyres).
Andy Stothert has done a lot of research and can be found on the internet re Fiat`s infamous reverse judder and clutch burning.
mudmover
53
Wales
Low profile
Ford 2.2 140HP
We tried many ducato's but opted for the Ford 2.2 140HP.....It is fantastic..it is really nippy ( if thats such) and MPG really is impressive..we wnet to Swanage on the weekend wild camping and it average 29.4MPG over 320 miles..keeping speed betwwen 65-70 where legal of course.
IMO - the downside with transit is it looks like a DHL/Fedex wagon!
Try one before you opt for ducato!!!! There really is no comparasin the ford blows it away and ofcourse UK is more geared to Ford for Service.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Have a good look around, with your eyes open and brain fully engaged.
There are lots of things to consider, not only with the base vehicle, but with the quality as well - well known that the quality of new vans isn't as high as the older ones. Sit in them, make sure you are comfy long term - if you sit in some 8 year old vans, you may well notice a difference!
Check forecourt prices too - when you see a 2008 van selling for 25k, and a 2001 van selling for 24k ask yourself why. It may be that the older is more desirable - or could just be an awful interior - but do check these things out!
