Dripping toilet flusher (1 Viewer)
Apr 5, 2017
14
Hassocks
Panel van
4.5 years
:wub::yawn2::wub:Hi, I ve just joined but have been travelling in my campervan for 4.5 years just me and the dog.
I have just started a 4 week trip in France and the toilet flusher drips continuously, which fills up the casette quite quickly. Any suggestions how I might (temporarily) solve this?
funflair
19,346
30,235
Guisborough
MORELO palace
since 2012
Is your water a pressurised system or micro switch? If it's pressurised just switch the pump off.
Martin
D
Apr 5, 2017
14
Hassocks
Panel van
4.5 years
No it still drips with the pump on, I ve also taken out the fuse behind the casette
funflair
19,346
30,235
Guisborough
MORELO palace
since 2012
Well I guess it has some sort of solenoid valve to open up to flush if you can't repair or replace the valve disconnecting and sealing the pipe might be the next best option until a full repair can be done.
Martin
D
Apr 5, 2017
14
Hassocks
Panel van
4.5 years
I am not very practical, The pump is under one of the sofas, next is the fridge and then the toilet. I ve seen some pipes but I don't know where I would access them
funflair
19,346
30,235
Guisborough
MORELO palace
since 2012
If you post your van make and model somebody might have the same and know the ins and outs of the piping.
Martin
D
Apr 5, 2017
14
Hassocks
Panel van
4.5 years
It's an Autocruise Rythm 2012
Jul 13, 2008
3,739
3,862
Low profile
Turn the pump off, reduce pressure in the system by turning tap on until no water runs out, water will probably still run a little into the toilet bowl but not much.
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Sometimes mine has done this after storage. Might be s bit of grit in the solenoid valve. I've always find it clears after a few vigorous flushes, but if not the valve might need replacing.
D
Apr 5, 2017
14
Hassocks
Panel van
4.5 years
Thanks boring frog and reallyretired
I am just about to leave the campsite I will try emptying the taps and see how it goes
I have to put the fuse back to flush which I will do this afternoon.
D
Apr 5, 2017
14
Hassocks
Panel van
4.5 years
Thanks boring frog
Taking the pressure of works, but as soon as the pump is on it leaks again, I will have to get it fixed when I get home,
Sorry to reply so late but WIFI sporadic.
