draing down (1 Viewer)
N
Nobody
on draining down taps inside had ice formed over is this going to cause problems when i use van at later date
scotjimland
2,324
10,061
A Woosh bang
maybe, maybe not.. the ice can crack plastic taps and pull pipe joints apart..
once it's a bit warmer I'd suggest to fill up and test.
deisel doctor
74
19
stowmarket
burstner
Going on from your question if the fresh water and waste water tanks are drained and left open the boiler and toilet empty taps open is there any thing else?
GJH
29,450
38,827
None, now sold
2006 to 2022
Unscrew the shower head and blow down the hose - Don Madge tip to empty it of water.
Open cupboards/lockers, prop up seat cushions (and mattress if a fixd bed) to help air flow and avoid cold spots where condensation may occur.
Use the van as much as possible year round :thumb:
43,329
49,444
your pump will be lower than all the taps and even though nothing but air will have come out the taps there will be a little water left in the pipes and it will settle to the lowest point...probably your pump.
if its accessible I would undo one, or both, of the pump unions or unscrew the filter and drain out the last drops of water.
if you have a submersible pump ignore the above advise :Doh:
11,862
43,022
Planet Earth
A van
Over 25 year's
Dont stop using it atall just use bottled water or water contaner if you dont have frost protection and keep calm and carry on camping
11,862
43,022
Planet Earth
A van
Over 25 year's
dont think so just make sure you have got most off the water out leve drane on heater off open all taps as previus poster said blow down shower hose drane and remove conections bothe sides of pump and it should be fine only usualy problems when ice hasent got room to expand :thumb:
oldun
747
162
St Neots
VW Campervan
Since 2001
Unfortunately in nearly all vans there will be low points in the water system where water will remain and may cause a problem. It is very difficult to get rid af all of the water.
Also water may remain in a fresh water filter (if you have one).
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Wouldn't it be easier if we lived somewhere warm?
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
A lot of American m/homes have a 'city water' connection , I don't know if any Euro vans have the same thing?????------but with our city water connection I just screw on an air line adapter and blow the system out with air (just a small power-pack type compressor)---------opening one tap at a time------------then leave everything open-----not forgetting the outside shower (l often forget to close it when filling the system). There is pipe-work hidden in areas where water can lay (and freeze) and be hard to get at to repair:Sad:
On our camper we have a tee'd pipe which is designed to suck antifreeze from a container instead of water from the tank-----fantastic idea---but I have not yet used it !!!!--------RV anti-freeze is available from most RV spares places-----------I always drop a bit into the 'U' traps on sinks and shower.
Nigel & Pamala
