Does This Sound Plausible?? (1 Viewer)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
I was originally thinking of using 'mini' type exhaust bobbins , (one on each corner), to secure a 3' x 2' solar panel to the roof of our Hymer, drilling and tapping the roof to mount it. However, someone mentioned last year that they had stuck theirs on using a special 'glue'?
And so, do the team think it would be plausible to saw off the threaded rod(s) on on one side of the mini bobbins, and stick them to the roof? Would the surface area of the flat bobbins be strong enough to secure the panel? Mini bobbins are great, because they do allow a large degree of flexibility through movement, rather then having the panel secured directly to the roof. Any ideas on this would be gratefully accepted.
Ta, Dave. :Smile:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
The special glue used is Sikaflex. I would not think bobbins would have enough area to hold solar panels down. Am not a lover of drilling holes in motorhome roofs either. I have 4 panels on the roof all secured with Sikaflex with no problems. Make sure you leave an air space under the panels.
Merle
424
226
Wiltshire
Since 2008
Sorry you have lost me with 'exhaust bobbins' but my panel was professionally fitted with corner brackets Sikaflexed to the roof, no drilling of holes at all other than for the gland where the cable comes through into the van. It has been fitted for 3 years and been no problem.
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Ta, Dave. :Smile:
Hi Tootles, I have used Silkaflex fairly extensively on all three of the sailing yachts I've owned and it is brilliant stuff, however I can't get my head around why you need the suspension that these bobbins will give you.
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Corner fixing brackets on Ebay less than £20 for 4 and no drilling using Sikaflex.
Your choice
Jun 17, 2012
2,933
9,932
North Essex
Autotrail Delaware
>12 but <13
Hi Tootles, As you will see from the picture my Solar panel is sitting on 4 corner mounts. They are stuck to the roof with Sikaflex 512. This stuff will go on creamy and then become cured but not hard. Sticks like the proverbial ...............I have drilled mounts and used stainless steel self tappers to attach panel to mounts
No need to :Eeek:drill roof :Eeek:
Just 1 hole through roof for cables via box, also stuck with Sikaflex 512.
Peter
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Broken Link Removed
or you can use some ali angle iron ---both glued to roof using Sikaflex or tool station pu 40 :winky:
terry
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
These exhaust mounting bobbins act as a shock dampener. I have used them extensively in the past as generator shock/vibration absorbers, and of course by using them you can remove the panel to replace if necessary.
I wasnt aware that special corner brackets were available, and so thanks to all for that. :thumb:
Jun 17, 2012
2,933
9,932
North Essex
Autotrail Delaware
>12 but <13
Three of those bobbins hold the air filter casing to the engine bay of my Ducato.
They broke when I tried to remove the casing to get at the fuel filter.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
Ta, Dave. :Smile:
In a word NO
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
[HI]These exhaust mounting bobbins act as a shock dampener.[/HI] I have used them extensively in the past as generator shock/vibration absorbers, and of course by using them you can remove the panel to replace if necessary.
Yes I knew exactly what you meant by your description, I used one on the back of an old chain saw where the rubber mounting had failed over the years, best of luck with the Silki :thumb:
haganap
12,762
26,457
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Tootles, just get some brackets or corner fixings, use sikaflex great stuff.
Mine have been from one van to another including camos dome using the stuff, using your bobbins will require roof driilng so why bother increasing the risk of damp
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
The threaded parts of your bobbins will not be long enough to penetrate your roof and get a nut on it anyway, and you would need a washer to spread a bit of the load. Get the plastic mounts and mastic it down with Sikaflex. I started a thread on "solar" forum on this site "Sikaflexing" got lots of good advice and tips like using 3mm tile spacers to get your depth of mastic correct, do a search.
I used bolts as well but that was to do with the construction of my roof.
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
In a word NO
Thanks for your in depth reply......:Smile:
Just ordered the corner panels, and the through-roof marine two pin plug/socket. Many thanks to all of you who have helped out on this. :thumb::thumb:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
This sounds like a problem area waiting to happen,(built in weakness) whats up with the standard well proven cable gland
G
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
G
Had two on the roof of the boat for 20 years, no problems, and this way in can be removed at any time, just leaving the capped off socket. :thumb:
Feb 29, 2012
361
225
Reading & Surgeres France.
Hymer 584
Motor homing since 1998.
Good afternoon, earlier in this thread someone mentioned Tool Station PU 40.
Seems a good price compared to Sika. Has anyone used it & with what success ?
Would be interested to hear.
Thanks.
Barrie.
