depends on the age of the vehicle, after 2012 they must be type approve
as far as i know anything structural bolted or welded to the van needs to be type approved....a towbar is structural, whereas a body mounted bike rack is an accessory.If the 'towbar' does not have a tow hitch, and is only used for the purpose of fitting a bike rack, is this still the case?
Bear in mind that any towbar with or without a ball fitted and associated wiring is now a part of the MOT if a ball is fitted that is also a part of the MOT now - unless of course it has a cover on it and then the tester cannot remove the cover to look at it
Hi Geo i remember on a previous post about towbars that you said that the law related to vans and not motrohomes. Is this correct or have i started it all off againoh:
