Diesel Additives (1 Viewer)
DuxDeluxe
14,658
72,784
Planet Zog
A woosh bang van
since 2008
Modern vehicles using modern lubricants and good quality fuels need no additives whatsoever. My work van and my "new" camper have both don e over 200,000 miles and as far as I can tell from paper trail evidence no additives were ever used in either of them. I can be pretty certain of this as I bought both vehicles as one business owner vans, the work van I actually bought directly off its original owner and that made 195,000 miles on the original clutch too.
D.
As an aside.....all pump fuel available and sold in the EU is of good quality. It has to meet minimum standards; the same standards that the engines are designed to run on. Plenty of threads on fuel quality, so I ain't going to repeat what I've said many times before, except that fuel quality used to be my job.......
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Absolutely agree, everyday pump fuel from ANY regular supplier will do although I only use Shell Vpower (or whatever they call it this week) in the racecar as that is what it gets mapped on.
D.
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Since 2010
Might as well pee in the wind, or the oil filler
D.
I put that in my car for the first time a month or two ago. Its only a 1.1 but small and light. By christ you can feel the difference. Doubt my car was quicker but it was very much more responsive.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Unsure if this is still safe with multi point injections but a wee half gallon of petrol in a full tank of diesel is ment to keep thinks clean and if smoking 2T oil in the fuel is meant to help.
NOOOOO!!! the pump will probably seize as the petrol will wash the incredibly tight clearances allowing no lubrication and possible touching. They only allow biofuel to 10% for the same reason. The diesel oil has all the lubrication the pump needs.
This might be OK on the lod 608 Mercedes engines of 1980 and before but not the super high pressure one with common rail injection.
Cant remembe if Bosch or Lucas pump but my pug 306 1.9 non turbo could take 100% veg oil. I never did try it but did a 50/50 mix what was fine. This was in the summer months as i understand the oil is thicker till warm. My present van has the pug 1.9 non turbo engine also so i must look into the pump thing as i could be saving a fortune.
Handy forum for tight gits and green hippys
http://www.vegetableoildiesel.co.uk/mybbforum/
TheBig1
17,630
43,309
it really is worrying what some stupid people believe and waste money on, so risking damage to a modern engine
D
DL42846
I have a couple of work vans, A sprinter with six hundred and twenty thousand kilometers, a Movano with six hundred and ten thousand K, A Renault Scenic with three hundred and forty five thousand K. All going very well without any engine issues. None of them have ever had any additives. Oh, except perhaps the Renault where I half filled it with Petrol twice and rove it till it ran out.
Lol, i did that twice in a works Pug 309 back when they were new. Lucky it was the start of the shift so i could run it through. Could be a bugger to start at times and i never used 5th gear till i got it topped up again :D A friend did it in Manchester but lucky hitting the motorway north so just ran that through also. Nether car had issues. Another thing we noticed when we changed to the 306 when that came out new the work got two. The supervisors one was run in and the staff was ragged from day one. The staff car was in the garage less when we were getting on to 150K + miles and it also had a 5mph faster top speed.
Humsafer
Apr 8, 2015
321
292
Lincoln
coachbuilt
15 years
Wow! that's that then, thanks for all your replies and I did have a good laugh reading them. Never was in danger of buying but just thought I would ask.
