diagnostic port ducato 2.8jtd 2001 (2 Viewers)
D
dandj
hi there
sorry, another question :)
does anyone know where the diagnostic port is on a 2001 ducato 2.8jtd? I have a friend who owns a garage and will diagnose a fault for me, but we need to know the port type and location.
tried googling it and got no conclusive answer and looked in the couple of places some said it migth be on a fiat forum but no joy (guess because for a van not a motorhome)
thanks in advance
Darren
Braunston
1,408
7
Hi,
Are you sure the 2001 ducato has a diagnostic port,
I have a 2004/5 ducato and its under the fuse cover on the righthand drivers side albeit you have to look up under the remaining part of the dash, hope that makes sense, its not visable looking directly at the fuse holders.
thanks in advance
Darren
Our 2003 2ltr is under the steering wheel. I think the EU spec says it must be within 500mm of the steering wheel ( or something like that ).
haganap
12,762
26,468
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
if it has one the previous answers cover it. Is it a 2001 model or actually registered in 2001? has it got a proper fiat badge or the fiat lines?
You could also try the fiatforum, very uselful The FIAT Forum - For Talk On All Things FIAT
hope this helps :thumb:
D
dandj
found it
well, I found it, thanks for the replies but you all missed :)
on a LHD hymer fiat ducato 2.8jtd the diagnostic port is a 3 pin with 2 wires with a plastic cap on it, its on the right hand side in the engine bay, attached to a large black plastic panel (which I think will be the ecu). hope this helps others, took some finding.
can now get on with the diagnosis :) my cooling fan is not working, swapped out the fan as that was dead, put in a new thermistor just to be sure and tested all relays, all ok, so its wiring or ecu :-(
haganap
12,762
26,468
planet earth
hi there
Darren
Ok Darren, you beat us but my friend there was just a tiny bit of information missing. ie a left hand drive A class built motorhome will naturaly have differences from a standard rhd 2.8 jtd. ::bigsmile::Doh:
