Desp help ... (2 Viewers)
snowdrops
759
553
Wales
van conversion
2 years
Ford transit jumbo won't start. Won't turn over but radio works. Stopped for brekky in picnic area :( got lights on dashboard.
Jul 29, 2011
2,697
22,243
Urmston, Manchester
Former owner.
June 2012
Need more info, what happens when you turn key, nothing, tries to start, just a click, might help to point to problem.
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Dodgy alternator or duff flat battery maybe. Are you in the AA or RAC?
Bacchus
412
4,236
Staines
A Class Hymer
Also try putting the headlights on - if they won't stay bright for a couple of seconds or dim right down when the engine tries to turn then the battery is probably kapput. Obviously don't try this for too long.
If the battery is u/s then beware of "getting going" because you may conk out somewhere less agreeable!
CWH
5,151
247,518
WildAx PVC
From November 2013
AA RAC Greenflag whatever?
PS don't tell them you're in a layby - AA wouldn't come out to me one time because I'd managed to get off the road - they said they were an emergency service only and if I wasn't on the carriageway, I wasn't an emergency!
321
292
Lincoln
15 years
Once had the same problem on a Granada, eventually traced to a loose connection to the starter motor.
Rob and Val
1,906
2,677
Talbot Compass Calypso
Since July 2010
Had this happen to us recently. Had driven 30 miles. Stopped for about half an hour. Went to re-start. Lights on dash but engine would not turn over. It was a loose wire, as Humsafer says.
parknride
1,400
4,749
cumbria
c class
since 1988
Happened to me had refuelled 10 miles previously, put petrol instead of diesel in:doh:
Hope you get sorted
Mikey RV
4,905
24,271
Devon
Burstner Elegance I821G
Since 1977
Could have been a loose battery connection, check them out.
bigtwin
5,244
9,948
Derby
Concorde
Started now. Don't understand. Only thing we did was arm and disarm non starter. Not sure what happened. Just very grateful it has . Thanx. Will keep an eye :/
If you have an immobiliser, it could well be that. Your 'arm and disarm' may well have sorted it.
On some bike alarm/immobilisers, they can get interference from radio masts (often not visible at petrol stations) or overhead power lines. Moving a hundred yards or so can clear the problem - not so easy with a motorhome though!
Ian
PhilG
1,582
4,091
leicester
euramobil 810
since birth
Dirty exciter wire connection on the starter motor.. small wire that goes onto a spade connector on the starter motor. Had that a few times over the years
snowdrops
snowdrops
759
553
Wales
van conversion
2 years
Thanx everyone. Not happened since thank goodness. Must have been an oddity. Bit of a scare on day 1 of 3 weeks in France !!!!
Scattycat
920
1,262
Mayenne, France
Rapido
It happens all the time. You've probably just inadvertantly pressed the imobiliser button. It often happens with me when I put the keys in my pocket
