Design problem with my van? (1 Viewer)
Jan 21, 2020
257
163
Burstner
Just playing with my my van as I have not yet had a chance to use it, picked it up late february! :cry:
Put up the awning today as less windy, just to see how it all works and check it was all okay.
My plan was to purchase, either the full privacy room or the end pieces, so I could set up a contained area for my dogs, probably install some track for my old caravan draft excluder!
However, having set up the awning, and marvelling at its 4.5M length, I suddenly realised that if I installed a privacy room, or rain shield, I would no longer have access to my garage!
I really cannot think of a way around this but thought I would through it out in case anyone has any bright ideas!
Robin
Picture attached to show the problem.
May 7, 2016
7,335
11,865
West Sussex
Malibu Van 640 LE K
Since 2003
I wouldn’t say it was a design problem with the van. The awning might be a bit big or badly located but when I had one I just wound it out to provide shade and wound it away at night. The addition of privacy rooms was possibly not anticipated in either the design of the van or the awning.
53,910
151,899
Why didn't you go for a shorter awning?
Surely you have only got to unzip the end panel to get at it, or whats wrong with using the other door.
May 7, 2016
7,335
11,865
West Sussex
Malibu Van 640 LE K
Since 2003
Very frustrating to have a nice new toy and not be able to take it out to play with.
ceejayt
3,246
5,876
Stamford Bridge - Yorkshire
RS Elysian A Class
This awning question would seem to be a first world problem
I used to have a van parked next to the house ready to go. Now I just have a white elephant ?
lorger
9,697
90,870
Dumfries
Knaus Sun 650MEG
Mind sound daft but don’t you have a door on the other side
Jun 8, 2019
4,931
18,760
Bexley Kent
Given up Motorhoming
May 2019
But even worse when you know how much fun it is then you get restricted.
R
Jan 21, 2020
257
163
Burstner
I really like the idea of using the other door, if only I had another door! ?
I will have a look at some of the Thule videos again but I think it might be difficult to move the side out as far as I would need But it is probably the best idea if I can make it work.
Many thanks for all the responses.
Jun 8, 2019
4,931
18,760
Bexley Kent
May 2019
Could you not get a purpose built end screen with a Velcro or zip window/door. Might cost a bob or two but small price compared with cost of van?
Apr 11, 2015
5,452
55,860
hull
Laika Ecovip 300
drive away awning? the door to the garage would be in the 'porch' just re-read OP oops no good as a dog compound
ctc
Oct 12, 2015
1,531
2,564
Crowle
Hymer b680
New
Put the awning out then drive forward to get in the garage, when you've finished reverse. You can repair it when you get home. Simple.
treetops1
1,599
1,759
yorkshire/ lincolnshire.
Sold last van-
a long time,since 1996
We used to put the full room up and leave the garage door wide open .with it being fully enclosed never had a problem ,also had a temporary shelf fitted across the door opening ,worked a treat ,
32,705
66,753
Use some suction clamps in the 2 blue positions I've marked then secure the awning panel edge (yellow) to them so it angles out stays clear of the door ...
R
Jan 21, 2020
257
163
Burstner
unfortunately a chunk of my garage would be outside of the awning, so leaving it open is a non starter! Unless I can find a way to get it inside the awning, in which case I can close it anyway.
R
Jan 21, 2020
257
163
Burstner
Minxy Girl, that sounds like a real solution.
really appreciate the suggestions, especially the tongue in cheek ones! :LOL::LOL::LOL::LOL::LOL:
R
Jan 21, 2020
257
163
Burstner
Several people suggested the other door, I did see that on many vans I looked at, the garage had a door onboth sides.
However, ours only has the single door, which is a real shame!
Steve and Denise
5,313
14,154
Spalding LINCS
A Class Carthago
Since 2008
If you use wind blocker type you could use an awning rafter to hang your end panel on.
From experience privacy rooms are hard work and very heavy.
Jan 11, 2010
2,757
9,629
Chester
Auto-trail
It most certainly is a design fault same problem with our Autotrail the awaning sides come down over the gas locker at one end and a window and the rear locker at the other.
We just put everything we might need at the other side of the motorhome, (locker goes all the way through) and get it out from that side, we put cling film down the window so the awning doesn't mark the window.
May 7, 2016
7,335
11,865
West Sussex
Malibu Van 640 LE K
Since 2003
I still don’t see it as a design fault if someone has fitted the awning in a silly position, or put on one that doesn’t fit. I suspect the designers of both motorhome and awning expect the awning installer to position a suitably sized awning in a sensible position. If it is a factory fitted one then the fault lies in the specification not the designs.
R
Jan 21, 2020
257
163
Burstner
Looking at the different Thule options, the rain blocker looks like it might just work and appears to be the cheapest and lightest solution.
i will keep investigating!
Jan 11, 2010
2,757
9,629
Chester
Auto-trail
It's an Autotrail the are inbuilt to the side of the motorhome by Autotrail, specification has nothing to do with it, Autotrail designed the side and roof panels complete in their design was an awning, windows and doors.
Poor design one would think by people that never owned or used a motorhome.
