Cutting nylon sheet (2 Viewers)
Nov 6, 2013
3,201
229,825
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
I hope one of you very knowledgeable Funsters can help.
I have bought a piece of 10mm nylon sheet to use as a mounting plate for my newly aquired satellite dish. I've been waiting all week for it to arrive and now it has I an having trouble cutting it. I have a jigsaw but the blades get too hot and melts the nylon, fusing it together again :Eeek:
Is there a secret to cutting this material?
Unfortunately, I don't have a band or scroll saw :(
Bailey58
8,825
29,637
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Wouldn't a fine tooth hand saw go throught it more slowly and generate less heat>
53,493
150,284
You can do it with a jigsaw, sounds like you have running too fast, use it on a low speed and let the blade do the cutting don't force it.
I would question the use of nylon for the base not sure how well PU adhesives with stick to it, I would have used 2 or 3mm aluminium sheet.
Baycott
Nov 6, 2013
3,201
229,825
East Sussex
Hymer B574DL
I did check with the manufacturer and they said Sikaflex will bond perfectly OK.
Jul 29, 2013
9,071
18,565
Salisbury
Hymer B678DL A class
Just use a hand saw the will work fine (a Jack or similar)
Jul 29, 2013
9,071
18,565
Salisbury
Coping saw for the curves? I know it's easy for me to say as I was a carpenter & joiner in a former life.
2,347
10,197
you mean a wood butcher.. :whistle:
this is high tech nylon.. not tree wood ;)
Dave K
1,311
2,477
Somerset
Pilote P740C
You can buy jigsaw blades for cutting acrylic, I think Bosch do some, maybe try somewhere like Screwfix, as said before cut at a slow speed to generate less heat
Baycott
Nov 6, 2013
3,201
229,825
East Sussex
Hymer B574DL
Thanks Dave, I did exactly that and it is now finished apart from tidying up the edges.
Thanks to everybody for your suggestions. I knew I could rely on the Funster Family again :notworthy2::notworthy2::notworthy2::notworthy2:
Dave K
1,311
2,477
Somerset
Pilote P740C
Looks like a fine bit of cutting out, if I'm looking for an apprentice I'll know where to come :D
patnlee
17
6
Shrewsbury
Autocruise Starspitit
Nylon (66 ?) is hydroscopic and can absorb water which may reduce the effectiveness of the adhesive. On the Permabond site they say:
"Difficulties Bonding Nylon
Sometimes bonding Nylon is difficult because the surface can have a “greasy” feel to it (due to slip additives). Even wiping the Polyamide surface clean with an alcohol-based cleaner will show little improvement as the slip additives continue to migrate to the surface. It is possible to “dry-out” Nylon before bonding – leaving it in the oven at 60°C for several hours or overnight will reduce this issue."
Probably worth doing if it fits in the oven !.
11,956
16,570
Just out of interest why did you not leave it as a full rectangle with (perhaps) rounded corners? Your rather excellent workmanship will not be appreciated by passing aircraft or perching birds :).
Baycott
Nov 6, 2013
3,201
229,825
East Sussex
Hymer B574DL
I have to confess, I did think about that after I had started cutting it :blush:
But my initial thought was to make it as the original and once the cutting had started there was no going back. :doh:
18,035
48,145
It looks like the silhouette of one of the Mr Men. :) Mr Bowler Hat?
