Curious (1 Viewer)
Apr 29, 2009
2,321
1,991
West Yorkshire...Halifax
Vanless....BUT....!!!!
Er indoors has been messing with the sat system and it came up NO SIGNAL RECEIVED and then a number which she said was 29 I've seen the message before but with differing numbers (ie) 29..26..36............ anyone know what the numbers mean or indicate...just a bit curious thats all
43,331
49,480
really helpful this one ,
NO IDEA:ROFLMAO::ROFLMAO:
sorry mate...:Blush:
could be degrees east if you have an auto dish.....just a thought
I know what 42 is.
Benwick Rambler
42
Cambridgeshire
3 years
Mondo,
I used to get this message on my Oyster system until quite recently. My problem was caused by an Arab satellite which was located close to the Astra satellite. My Oyster system would go into automatic search mode and then lock-on to the nearby Arab satellite, giving the message “satellite found” on the control box but the TV displayed the message (no satellite signal being received).
This problem could sometimes be solved by lowering the Oyster dish as starting again, but was very hit and miss and could take many attempts to overcome and sometimes not at all.
I discovered at the Oct 08 NEC motorhome show that my Oyster system needed a software upgrade and took the opportunity recently to visit TSC at 12 Denby Lane, Grange Moor, Wakefield, WF4 4ED http://www.1oyster.co.uk The proprietor, Robert Jackson was able to remove my Oyster control box and install the software upgrade in about 30 minutes. I believe he will also do this if you post your Oyster control box to him. Problem now solved for me and Oyster quickly locks-on to the correct Astra satellite.
As I don’t know what type of system you are using, then the above may not be applicable to you. The following link to Sky may also help. http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=a18bb219-5076-43c0-990f-d7d97acaca2d&articleId=3571610
Brian
Satandpcguy
Jun 18, 2008
694
424
Gandia, Valencia, Spain
Don't own one yet
i had a lsit of the error number codes...
but then one day i decided to try them out....and got three different numbers for when i disconnected the cable from ythe dish...so i did not persue it further....
maybe it is a random number generator for lottery numbers???
